It is currently Sun Aug 10, 2025 5:43 am
 Post subject: Engine Question
PostPosted: Wed Apr 16, 2008 2:59 pm
Hey, my mini is going well kind of. i have a small problem in that it runs for 10-15mins and then will die and wont start again until it cools right down. Does anyone know why this be?
Any help would be appriciated
Thanks Blake
PostPosted: Wed Apr 16, 2008 3:05 pm
Some more details of the motor would help , is it an electric or mechanical fuel pump ? Pulsar or similar electronic distributer or points ? Have you checked to see if you have spark or fuel when it stops and won't start ?
It could be electrical with the coil failing and overheating after running a while or could be points needing adjusting or replacing . It could also be a fuel pump problem that only cuts in when it's hot but I'd lean more towards electrical . Nest time it does it get someone to give you a hand and check if you have spark , then take the distributer cap off and open the points with an INSULATED screwdriver while the ign is switched on to see if you have power to the points .
PostPosted: Wed Apr 16, 2008 3:37 pm
Well its an 1100cc with mechinical fuel pump, orginal Dizzy, with new ignition coil and new spark plugs.
If it is the points what kinda money am i looking at to replace the points?
PostPosted: Wed Apr 16, 2008 3:43 pm
Points are dirt cheap (under $5 last set from memory ) , you say the coil is new , is it the same type as the previous one ? If you put a coil that needs a resister on it on a car without it you'll burn the points out and have problems (normally it'll just stop though , no going again when it's cool) .
PostPosted: Wed Apr 16, 2008 4:04 pm
check that the fuel tank breather isn't blocked
PostPosted: Wed Apr 16, 2008 7:14 pm
Long shot, but check the rocker clearance on the exhaust valves. :wink:
I had a Chev 4 paddock basher once that did that, I found the prob was the exhaust valves got longer with heat, this closed up the clearance then there was no compression until it cooled for 15 mins. :roll:
PostPosted: Wed Apr 16, 2008 8:17 pm
Thanks i'll give it a go and see what happens.
PostPosted: Wed Apr 16, 2008 8:19 pm
what coil did you put in
PostPosted: Thu Apr 17, 2008 4:09 pm
The coil i put in it was one i had in another mini that i had a couple of years ago and at the time it was new and worked on it so yeh i dont know what the go is. Im not sure what the coil is.
PostPosted: Thu Apr 17, 2008 4:15 pm
with the engine cool (but ign on) check to temp of the coil. i know you said its new but it sounds like a second hand one.
if it's hot it's knackered, and you're up for a new one. get a bosch GT40 (around 50 bucks from the usual suspects :))
78 Leyland Mini - Prince
PostPosted: Thu Apr 17, 2008 5:55 pm
Just a random question. Has anyone ever imported an engine from the UK? and if so does it cost a fortune?
PostPosted: Thu Apr 17, 2008 6:02 pm
There's a motza of local guys who do this in bulk. Brikworx, Josh at miniimports, etc etc.... They will save you a bundle on doing it yourself. But if something very particular has your attention then yeah it can be done. But be prepared to spend a bit of money.
PostPosted: Thu Apr 17, 2008 7:20 pm
:idea: id be looking at the condensor in the dissy if its the original points type, they are normally $5- $10 each.....i normally do that when i replace the points anyways. :)
 Post subject: Coil
PostPosted: Thu Apr 17, 2008 7:29 pm
Have you still got the one you took off :?: Try putting it back on :idea:
PostPosted: Thu Apr 17, 2008 7:46 pm
Yeh i tried putting it back on and it didnt work either. The car wont start now so im going to buy a new coil and replace the points and yeah see what happens then.
Users browsing this forum: Bing [Bot] and 118 guests
