It is currently Sat Aug 23, 2025 6:18 am
 Post subject: Whats my carbie
PostPosted: Sat Apr 26, 2008 11:50 am
Bit embarrassed to be asking this but exactly what type of carbie is this. It came on a 1990 Rover Cooper 1275. I know it's 1" 3/4.
PostPosted: Sat Apr 26, 2008 11:58 am
That would be a HIF44.
Cheers Pete
PostPosted: Sat Apr 26, 2008 12:25 pm
Ill second its a Hif44 which I also run on a 1100 8)
PostPosted: Sat Apr 26, 2008 1:49 pm
Hey - just on the side - I am bolting a HIF 44 to my rebuilt 998cc(1018 now and GR RE-13).
What needle do I have to run in this to let it run ok? I am using thie HIF as I want a bit of foolproof until I get the car all settled again, then the DHLA will go back on.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat Apr 26, 2008 3:17 pm
I is a mookenik
ill 2nd that 2nd with a hif44 im running one atm on tiny's warm 1100
PostPosted: Sat Apr 26, 2008 4:34 pm
looks like the pod filter needs a clean.
PostPosted: Sat Apr 26, 2008 6:39 pm
Yep definitely a HIF 44
_________________________________________________
1956 Bentley
1969 Morris Cooper S
1975 Citroen DS23 Pallas EFI 5 Speed
1982 Moke Californian 1275
1997 ZZR 1100 D
1989 Ke Laser Ghia-"The Runner"
2006 Holden Vectra CDX v6
PostPosted: Sat Apr 26, 2008 6:44 pm
Looks like a HIF44. :wink:
The 44 refers to the metric size of 44mm. They were originaly called HIF-6 using the old SU imperial system.
The system used the number of 1/8ths of an inch above an inch.
So the 6 = 6/8ths which equals 3/4.
So you add 1 inch to it and you get 1 3/4"
PostPosted: Sat Apr 26, 2008 10:49 pm
fully sick filter and yeah second a new pod filter.
PostPosted: Sun Apr 27, 2008 1:07 am
The 44 refers to the metric size of 44mm. They were originally called HIF-6 using the old SU imperial system.
So if it was referred to as a HIF 6 would I still get the correct parts? is it just the name that changed?
And I'm ditching the pod asap and going for a K&N cone filter :wink:
PostPosted: Sun Apr 27, 2008 3:58 pm
I am not sure if they just changed the name or if they redesigned the whole thing.
PostPosted: Sun Apr 27, 2008 4:00 pm
I believe on the HIF6 (as used on Metro turbo) the throttle arm is on the other side... compared to a regular HIF44.
PostPosted: Sun Apr 27, 2008 4:57 pm
I think that's all I need to know now, thanks everyone.
PostPosted: Sun Apr 27, 2008 5:11 pm
Well if you say 1 3/4 its a HHHHHHHHHHHHHHIIIIIIIIIIIIIIIIIIFFFFFFFFFFFFFFFFFFF44. The I.F stands for internal float :wink:
PostPosted: Sun Apr 27, 2008 5:19 pm
But do you know what the H stands for? :lol:
Users browsing this forum: No registered users and 247 guests
