It is currently Sun Aug 17, 2025 9:28 pm
PostPosted: Sat May 03, 2008 5:31 pm
You will need some flat strap steel 4.5cm by 3mm.... bend it thus....
The ears are about 1cm long and the two arms of the vee about 4cm each.
Across the ears (centre to centre of the strap) measures 5.5cm.
It works a treat :!: :D
PostPosted: Sat May 03, 2008 5:40 pm
Looks great. I will keep it in mind. :D
(I usually just stick a ½" sidchrome set spanner in the ring gear. It never pops out.)
PostPosted: Sat May 03, 2008 6:12 pm
Looks good,
I normally just use a main bearing but I might make one of these.
Matt
PostPosted: Sat May 03, 2008 7:04 pm
matt van'74 wrote:
Looks good,
Matt
ditto... an old bearing shell works a treat ;)
PostPosted: Sat May 03, 2008 7:21 pm
I clamp the flywheel with a pair of vice grips through the starter hole.. works a treat, so far.
this looks much better though Ima make me one.
blokeinamoke wrote:
PostPosted: Sat May 03, 2008 9:57 pm
I bought one of these off ebay.... a bit picey compared to a bearing shell...
but as I work alone mostly - I know it ain't going to slip ...
bolts onto starter motor holes...
 Post subject: Treat
PostPosted: Sat May 03, 2008 10:14 pm
simon k wrote:
matt van'74 wrote:
Looks good,
Matt
Ditto....but an old bearing shell falls out the first time you even look like moving the flywheel...this little unit wedges itself across two sets of teeth and up against the starter motor orifice :D
 Post subject: Re: Treat
PostPosted: Sat May 03, 2008 11:58 pm
9YaTaH wrote:
simon k wrote:
matt van'74 wrote:
Looks good,
Matt
never had that problem... but still, nice little gizmo Mick ;)
PostPosted: Sun May 04, 2008 12:02 am
I never have spare main bearing shells. I re-use them, I am a tightarse. :mrgreen:
PostPosted: Sun May 04, 2008 10:01 am
Well I was creative and built this, All with a 9" grinder, drill press and an arc welder :P
I even angled the edges so it would slot in nicely :D
PostPosted: Sun May 04, 2008 11:20 am
some one is showing off :D looks dam fine though chrome it and put it on ebay make a mint :lol:
PostPosted: Sun May 04, 2008 5:33 pm
so you file them and pop some foil behind them ?
blokeinamoke wrote:
PostPosted: Sun May 04, 2008 5:38 pm
You can use foil or even a cut up milo tin. :shock:
PostPosted: Sun May 04, 2008 9:15 pm
I just use a spare Wheels bearing race :lol:
Users browsing this forum: Bing [Bot] and 379 guests
