AEG163job wrote:
yep, sounds like fuel.
Carby dashpot oil level ok?
that's where I'd look....
the carb has a black screw in knob with a rod attached to it (the damper) at the top of the round 'bell' shaped part (the dashpot), unscrew it and see if there is any oil in there, if not, half fill it with a light sort of oil, or engine oil if you don't have anything else. I'n using auto transmission fluid
however, you really ought to get it along to an experienced mini mechanic and get them to sort it out, and show you what needs to be checked regularly
did I tell you that I won a
trophy?
