It is currently Sat Jul 19, 2025 12:10 am
 Post subject: Sump guard
PostPosted: Fri May 09, 2008 3:12 pm
I'm pretty sure this is a Moke sump guard and I want to fit it to a mini subframe. Is their a difference between the two subframes (Moke-mini)? because it doesn't seem to line up fully :? The front is good but from the rear (2nd pic) their is an inch gap along each side.
I think it will still fit fine but what do yous think :?:
PostPosted: Fri May 09, 2008 3:17 pm
pfft, attach it at the front, then put the jack under it.... it'll fit properly quickly enough
you don't live in a warm climate do you??
PostPosted: Fri May 09, 2008 3:30 pm
Theirs actually no bolt holes in the rear section only in the front and side wings which all fit perfectly :D and yes it is warm up here in QLD but I have a thermo fan for security :wink: .
PostPosted: Fri May 09, 2008 3:50 pm
Then put bolt holes in the rear section because one day your going to catch it in reverse and do a lot of damage. Apart from that its likely to flap underneath - sound annoying and eventually fatigue crack either the sub frame and the sump guard mounts.
PostPosted: Fri May 09, 2008 7:51 pm
Yep I would drill holes in the subby up the back so it would not catch when reversing :?
PostPosted: Sat May 10, 2008 12:07 am
I might see if some of those "cotton wheel" rubber mounts fit the gap.
PostPosted: Sat May 10, 2008 12:43 am
Kenno,,, if you fit that moke sump guard to a mini then you will be hitting just about every bump in the road with it,,, they are WAY too low for the average mini
just grab a decent "mini" one
PostPosted: Sat May 10, 2008 6:41 am
Didn't know they were deaper
PostPosted: Sat May 10, 2008 6:59 am
Yes , they don't fit as snuggly to the gearbox as the nice mini ones do , probably sit about an inch lower than a bare sump and all those things that you just got over you now don't ....
PostPosted: Sat May 10, 2008 12:41 pm
But with something that solid I'll just ski over those hurdles :lol:
PostPosted: Sat May 10, 2008 1:02 pm
They're marvellous for catching the oil leaks too. Then the dirt gets into it and you have to shovel it out down the track...
 Post subject: No drips for me
PostPosted: Mon May 12, 2008 9:56 pm
Rover Cooper
so thats why I don't have any drips on the floor after 8 months, thought I had a good sealed motor from Steve, now I will have to start cleaning the top of the sump guard as well as the dip stick. :oops:
 Post subject: One 2 many.
PostPosted: Mon May 12, 2008 9:57 pm
Rover Cooper
Hey mick, don't you have 1 to many cars on your signature list....
Users browsing this forum: No registered users and 72 guests
