It is currently Sun Aug 03, 2025 5:06 pm
PostPosted: Mon May 26, 2008 9:39 am
Hi,
Friend of mine bought a new UK steering rack, wants to fit it to his 65 Deluxe. He has cooper s discs, hi-los, adjustable lower control arms, adjustable tie rods.
Is there a problem with fitting this rack? I remember hearing somewhere that it turns too much (to reduce the turning circle in UK cars) and aussie tyres scrub.
Are the steering arms compatible?
Anyone got any first hand experience with these?
Matt
PostPosted: Mon May 26, 2008 9:41 am
This space for rent
From memory I think the steering arms need to be changed, but I've never used a UK rack myself.
I'm pretty sure the rack in my '65 is a UK type, never had any problems with it.
PostPosted: Mon May 26, 2008 10:29 am
should go straight in - it's the 13" wheels that cause problems with them
he might find that it doesn't last long though, heresay is that the new ones wear out quickly
PostPosted: Mon May 26, 2008 1:38 pm
The steering arms are compatible, but you should change them to match..
PostPosted: Mon May 26, 2008 9:29 pm
Matt
The black deluxe (ex lownblowns') that I've posted pics of had one in. Same lock -to-lock as the Aussie one. Be warned though that if they are worn in any way, they are non repairable.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Tue May 27, 2008 8:53 pm
Some late UK racks have stops fitted to reduce the steering lock so that Sportspack 13" wheels don't rub.
Mk II and later UK racks should have the matching steering arms (with little cast ears). However, I've seen many fitted with standard Oz arms. Seems to still work.
Cheers, Ian
Users browsing this forum: Bing [Bot] and 73 guests
