It is currently Sat Jul 19, 2025 7:12 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 31, 2008 5:15 am
:? Are you sure its the wheel bearing?
what type of wheel bearing are you using? ball or tapered
What type of noise is made to make you think it is the wheel bearing? and when does it make that noise??
PostPosted: Sat May 31, 2008 8:25 am
not tapered, and it makes the noise as soon as you start to drive the car
cheers allan
PostPosted: Sat May 31, 2008 6:42 pm
Could the inner pot joint be dry? They will make a noise.
PostPosted: Sat May 31, 2008 7:04 pm
teh admin God
teh admin God
It's sort of a continuous deep moaning, slight grinding sort of noise isnt it?
Did you do it today?
I should have come and helped. Drink the beer.
But i was busy being awesome. Beautiful day at Redpa :lol: .
Sir Namibian CAMEL of MONGOLIA !!!
Vrilen Snyson Racing: Finding us all a Vrilen
Asparagus: Experience the versatility
PostPosted: Sat May 31, 2008 7:16 pm
camel i would have been better off if you did not come around, and did your partner say you were awesome or did you just sit on your hand and think it was someone else again
PostPosted: Sun Jun 01, 2008 11:08 am
does the noise get worse when you go around corners (load up the bearing), does it go away when you apply the brakes or does the noise change slightly ,does it go away when you use the clutch, does it do it as soon as you start the engine and get worse when you rev it?
PostPosted: Sun Jun 01, 2008 4:57 pm
it only makes the noise when you are driving it, i changed the bearings today im going to burn the heap of crap i broke the plastic peice in the bearing so now im going to order a set of tapered ones and see what happens next weekend
cheers allan
