It is currently Tue Jun 24, 2025 10:16 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 31, 2008 11:46 am
d1ck0 wrote:
tinymorris1969 wrote:
twins are awsome i reckon the car runs 10x better with them even though ive had nothing but trouble with mine so far. but if your not interested in tuning all the time stick to a hs4 1.5" it will provide more then enough power. mine use to
Umm, why would you have to tune all the time?
My twins, once set up, have needed no further tuning. Obviously when doing a tune up I check balance (with a hose) and mixtures, but thats a 10 minute job and very rarely needs adjusting.
Dicko
Same here, I put twin S/H HS4s on Barney (1293) I just put a FuelMiser service kit in them first. Running fine with #6 needles, no problem.
ps. I'm sorting Tiny's out this arvo if he shows up. :wink:
PostPosted: Sat May 31, 2008 12:12 pm
This space for rent
Same here
And here too. Once I got my twins balanced, they've been perfect without needing any attention, beyond a one-flat tweak of the mixture here or there to suit the type of driving, conditions, fuel, etc.
PostPosted: Sat May 31, 2008 3:22 pm
sgc wrote:
Same here
Same had twin hs2's on engine for a few years and then put on HS4 twins....the only service and adjusting mine have required is the top up of damper oil every now and then.
