It is currently Mon Aug 11, 2025 4:31 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jun 02, 2008 10:17 pm
simon k wrote:
mad-mk1 wrote:
what are they like defect wise?
who cares - we're not from NSW!! :D
Simon,
I take it you are going then?
PostPosted: Mon Jun 02, 2008 10:33 pm
not on madmk1 just the delux, clearence is an issue as is teh 5 degrees of negative camber :D
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Jun 02, 2008 10:39 pm
High heel ninja
Thats way to much, 2 degrees is enough, with 5 degrees you lose to much tyre contact to the ground.
Doogie
PostPosted: Tue Jun 03, 2008 1:06 pm
Archangel007 wrote:
Simon,
I sure am Trickster ;)
PostPosted: Tue Jun 03, 2008 8:03 pm
Best of luck then - knock 'em dead!! :wink:
PostPosted: Thu Jun 05, 2008 12:26 am
Doogie
just cos it looks coool!
all easily adjustable but cheers for the heads up :)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jun 05, 2008 1:30 pm
Doogie
it only looks cool when you're going around a corner on 2 wheels with the tyre planted flat on the tarmac, otherwise you look like a poser :P
Users browsing this forum: Bing [Bot] and 166 guests
