3/8ths unf i believe
& for the guys who "Think" their brakes are fine without any rear valve (or without any guts inside the rear valve),,, well,,, you obviously havn`t hit the brakes in the wet yet hey?????????
funny that
well ,,, in fact it wouldn`t be funny if you locked the rear brakes & skidded sideways into a whole familliy of people would it?
the rear brake valve is exactly that... "A Pressure LIMITING Valve"
Not just a restrictor
that`yre 2 totally different things
Pressure within a system remains "EQUAL" even with a restrictor
however, when a "LIMITING VALVE" is fitted , then the pressure at that end of the car goes no further than the set spring pressure & shuts off any more after that pressure is reached
Please do some reading &/or get some-one to fix your brakes "Properly" for you
However,,, if you have drum front brakes then may i suggest you try to "Un-Adjust" the front brakes,,,,, THEN Bleed the sytem,,, & Then re-Adjust UP the fronts & see if that helps (which it should if you have drum type front brakes)
If you have discs then you`ll need it all "Diagnosed Correctly" before going any further
