It is currently Thu Aug 14, 2025 8:17 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 04, 2008 10:56 pm
Forum Graffiti
pristic wrote:
Mine has higher compression, 9.5:1 and its a daily. It runs like your normal mini off boost... under 2000rpm its quite sluggish but I am running an RE13T cam now... the motor was originally built with an RE13 cam, and very different setup and was worse under 3000rpm if you believe that... the turbo (actually the change in cam) made it friendlier and smoother at low rpm.
I assume that would be because the RE13 has more overlap because it's an NA style cam. The RE13T runs less overlap because boost doesn't like it... it tends to push the air where it's not s'posed to go..
PostPosted: Thu Jun 05, 2008 3:41 am
ausmini mod
ausmini mod
You assume absolutely correctly :)
Pete
Users browsing this forum: TartanRed and 202 guests
