Thanks Archangle, you`re a true sweetheart
These things in the pic are the last little fiddly bits that i needed to finish off that i was talking about a while ago, now they`re all nearly done, just another full day tomorrow to finish them all off & de-bur them all,,, i still have to smack all the dowels into the pulley bosses etc, broach the key ways into the mini cam pulley bosses & i`m in the process of the packaging them all up thing,,, so we`re just around the corner of having them on the market
There`s actually 2 types of these little thingys,,, one is the 8v type & the other is the 16v type, (both heads are sightly different where this flange piece fits,
so as you can imagine it`s been a bit of work tidying up 2 different programs with such a finicky little ning nong of a thing to design & fit, first the 8v item , make template, make a solid alloy piece from that by hand, measure & copy etc & make up a program for the CNC machin, make up test piece, re-design it a tad & change the program & make another test piece & dummy that one up, then mod that a tiny bit & then change the program again & make another test piece & & & & etc etc etc,,,,
Then do it all for the 16v piece too
fun hey????
Whew!!!!!!!!!!!!!!!!! so we`re nearly there,,, bare with me a little longer & i`ll have the whole dam lot packaged & then i`ll get to working out how much it all costs me.
cheers & thank you all for your patience
