It is currently Fri Jul 18, 2025 7:05 pm
 Post subject: wiring question
PostPosted: Thu Jun 19, 2008 10:27 pm
Hi all
I was just wondering if the depress function on the indicator stalk operates the washer squirter deally or the horn?
I have test rigged the wiring and now a light comes on on the dash board when I depress said stalk..
oh lastly,
what terminal on the alternator remains vacant?
cheers guys
blokeinamoke wrote:
PostPosted: Thu Jun 19, 2008 10:29 pm
High heel ninja
If its one a clubman the end of the blinker stalk is for the horn, the washer switch is down n the centre swich panel.
Doogie
PostPosted: Thu Jun 19, 2008 10:32 pm
thanks mate
blokeinamoke wrote:
PostPosted: Sat Jun 21, 2008 6:15 pm
another questions
I have a rouge brown wire with a blue trace, its constantly live if that helps.
also should my oil pressure sender and my temp guage be live aswell?
thanks guys
blokeinamoke wrote:
PostPosted: Sat Jun 21, 2008 7:19 pm
I can't remember what the brown/blue wire is supposed to do without my manual, but yes there will be a voltage at the oil switch and the temp sender . The oil switch acts as a switch to ground on the ground side of the oil light, the sender acts as a variable temperature dependant resistor for the gauge(but it's only 10 volts here).
