It is currently Mon Jul 21, 2025 4:14 pm
PostPosted: Thu Jun 19, 2008 7:24 pm
i am wondering how much difference there is in ride.
witch brand spax/gaz etc you have and what the difference is when the shocks are set to hard and soft.
are they worth the money or should i just get rebound ajustable shocks.
how about the fast road coil springs.
i have a bad back so i need a smoother ride but i don't want to sacrafice handling.
PostPosted: Thu Jun 19, 2008 9:42 pm
minis won Bathurst and the Monte Carlo rally on standard hydrolastic suspension, which gives the smoothest ride.... and won't cost you any extra
PostPosted: Fri Jun 20, 2008 8:18 am
But some of us want that extra edge Simon, and dont forget that little thing called R&D which allows progress and improvements to take place.
I doubt if coilovers would have been readily accessible back in the mid-60's
Yes, I am running coilovers - GAZ. Have not tested them on the road yet. Stay tuned.
PostPosted: Fri Jun 20, 2008 10:24 am
I have coil overs in the Midas and we also use them in the Clubman sportcars, if you want a smooth ride don't even bother thinking of coilovers , they do a great job as a performance combo but for handling they are very hard and stiff and that does not equate to a smooth ride
If its a van I believe the good doc is going to do a hydro van soon and that would be probably the best all rounder
Jon
PostPosted: Fri Jun 20, 2008 3:25 pm
hydro
or moultons smootharide
or
coil springs
