It is currently Sun Aug 03, 2025 2:03 pm
PostPosted: Tue Jun 24, 2008 6:26 pm
If it turns over, than there is no point in rocking it, because if it turns over than the starter isn't jammed.
Does it sound like it is trying to fire or does it just keep turning over and over?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Jun 24, 2008 6:28 pm
A few things to check:
* Fuel in the carb
* Spark at the plugs
* Check all your leads are on tight
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Tue Jun 24, 2008 6:41 pm
defenitly have a fuel flow, dont no about the leads and plugs. what would be the easiest way to check for a spark.
PostPosted: Tue Jun 24, 2008 6:45 pm
Give Ash some flowers Nick .
Earth the lead against the block and watch for a spark, do that for all the leads.
PostPosted: Tue Jun 24, 2008 7:00 pm
i thought so
thanks, leighton
 Post subject: no start
PostPosted: Tue Jun 24, 2008 8:19 pm
Still guessing at what the porob could be ??
"Let us remove your "SHORTS"
PostPosted: Tue Jun 24, 2008 9:54 pm
where abouts in the gong are you? if your close enough(eg, 10-20 minute pushy ride from nth gong) i might be able to come around and give you a hand on the weekend if im not too hungover
 Post subject: sparks
PostPosted: Wed Jun 25, 2008 10:09 am
just tried for a spark, i was getting a fair weak spark however it was still a spark.!!! :lol: when i started ignition the newly charged battery seemed to be giving up on me.. it turned over very slowly...
then when i disconected the battery the negative wire was hot
anyone got any ideas what is wrong?
is it just a crap battery?
cheers leighton
PostPosted: Wed Jun 25, 2008 10:20 am
im in figtree ill pm you if i havent workeed things out by the weekend
PostPosted: Wed Jun 25, 2008 5:37 pm
Leighton
I am also in figtree, did I meet you at craigs mini sale? I think I know your brother.
If you need a hand let me know.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Wed Jun 25, 2008 5:47 pm
yer i think i met you at craigs...
yer david hill...
yer what time can you come round ive got tennis till about 11.00 on saturday
leighton
PostPosted: Thu Jun 26, 2008 11:11 pm
pm sent
Ryan Filippi
Minis In The Gong
[email protected]
