It is currently Fri Jul 18, 2025 5:24 pm
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Fri Jan 28, 2005 5:56 pm
Marvin wrote:
1310/71 wrote:
What do you guys use for FTP to servers?
I use WS_FTPLE. When you install it choose the options to say your a teacher at a school using it for work at school as it's a "Limited Edition" it's free as long as you choose these options otherwise it won't install. Simple and easy to use.
Marvin,
Downloaded and installed the program you recommended tonight. Thanks.
PostPosted: Fri Jan 28, 2005 6:59 pm
Thats two Engines in NSW out this weekend 8)
PostPosted: Fri Jan 28, 2005 7:01 pm
Maybe 3.... :lol: 8)
PostPosted: Fri Jan 28, 2005 7:03 pm
8) Not Barney also :shock: leave it for Sunday and I can help you
PostPosted: Sat Jan 29, 2005 5:27 pm
Mine's out.
Engine lifter worked a treat.
My rattle was the harmonic balancer loose, worn on the inner diameter ie loose on the crankshaft. This seems to have stretched the timing chain (It may have been secondhand when the previous owner assembled the engine). The vibration also seems to have loosened the camshaft pulley nut a little as well. Other problem? I found was Doc's oil pressure fix thread - mine had the spring but no ball bearing!?
PostPosted: Sat Jan 29, 2005 5:40 pm
Check the crank key is not worn, replace it if it is. A bit of Loctite 262 on the crank nose and the bolt thread is a good idea. I don't use that silly lock washer any more. Neither do most race engine builders. :wink:
PostPosted: Sun Jan 30, 2005 12:37 am
Yep Mike (Mike) and I also pulled out his engine today without any problems and we took our time doing it...with on lookers :lol:
Yep Ill put up some pics tomorrow but Keith :? Sorry may be we can put a FAQ about pulling engines out...did you take picutures :idea:
PostPosted: Sun Jan 30, 2005 9:49 am
Gaf, do you mean me?
The grey learned one is Dr Mini, Doc, Kev or Kevin. This young whippersnapper (on the basis of being only slightly greying and an apprentince where it comes to Mini's) is Kevin also) :)
I didn't take any pics, but your idea about an FAQ (as is Anton's idea for an FAQ section) is excellent. Unfortunately my removal was less than ideal as I needed to keep the exhaust in place, so took the head studs out and took the engine out through the (removed) panel that the grille bolts on so as not to disturb the extractors- an advantage of a clubbie. Wouldn't be able to do that on a roundnose.
KB
PostPosted: Sun Jan 30, 2005 9:52 am
Sorry mate (Kevin 1310/71) yer it was you....
I took a few pictures but not to many and we were covered in Oil and grease :lol:
PostPosted: Sun Jan 30, 2005 10:00 am
Must be just a gafmo thing? I drain the oil out first!
You've seen my garage. I'll take some photos later just for interest sake.
 Post subject: pic added
PostPosted: Sun Jan 30, 2005 6:18 pm
Just for you Gafmo :)
KB
 Post subject: All set up!
PostPosted: Sun Jan 30, 2005 6:25 pm
Hmmmmm, Microwave, Fridge, grit blaster, chainblock...no need to go in the house at all really... :lol:
 Post subject: Re: All set up!
PostPosted: Sun Jan 30, 2005 6:36 pm
Nah, there's no toilet or shower and room service is on supply not demand! :lol:
kb
PostPosted: Sun Jan 30, 2005 7:01 pm
kb
Well at least you know the basic requirement s for a "doghouse"....good retreat when the fur is flying!! :wink:
PostPosted: Sun Jan 30, 2005 9:19 pm
:lol: 1310.... :lol: Yep I'v been in your appartment which is very orginized..Yep I totaly agreeI get into it....but it was not just my fault..But..I did have white cloths on :lol: :lol: :lol: :lol: :lol:
Did I care...Nope
Drainging the Oil...yer we did leave that till late but not one spilt :!:
