It is currently Wed Jul 30, 2025 12:28 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Urgent Help
PostPosted: Wed Jul 02, 2008 6:37 pm
Hi
I have been given a Mini to do up as a race car and it has the following numbers on the body
M2
22
003
PA
Does any one know what they mean and what year make and model the mini would be
Thanks
Shane
PostPosted: Wed Jul 02, 2008 7:02 pm
High heel ninja
Is it a clubman or a round nose?
Doogie
PostPosted: Wed Jul 02, 2008 7:06 pm
Hi
I think it would be better if you could provide more information, as already said, clubbie or round nose.
Also where are the numbers you have quoted?
Is there an id plate? Is there numbers on the radiator support panel?
Steve
PostPosted: Wed Jul 02, 2008 7:08 pm
Even a piccy would help as well!
Mini, its in my blood........
PostPosted: Wed Jul 02, 2008 7:13 pm
I would guess (and it is a guess) that it is a Mini S (or SS or LS) made between 73 and 78.
More info and I can narrow it down a little.
PostPosted: Wed Jul 02, 2008 7:19 pm
There are no other numbers on the body anywere.
M2
22
003
PA
As above is stamped in the bulk head fire wall
The starter motor has 1971 stamped on it.
Chassis plate and info is still in the shed 4 hours drive away
Thanks
Shane Cassidy
Motor Sports Media
CAMS Accredited Photographer
PostPosted: Wed Jul 02, 2008 7:22 pm
Do you know if its a clubman or a roundnose mini?
PostPosted: Wed Jul 02, 2008 7:23 pm
Its a clubman
PostPosted: Wed Jul 02, 2008 7:43 pm
Does it have a radiator shroud on the inner mudguard?
PostPosted: Wed Jul 02, 2008 7:49 pm
Yes it does its a complete body....but it has no other numbers on it any were
PostPosted: Wed Jul 02, 2008 7:54 pm
When the car was made it would have had numbers on the flat panel on the top of the radiator shoud.
So it has a chassis plate. If you can provide the first bit of the chassis number I can tell you what it is. The plate will also have a date on it.
In late 76 (I think) they deleted the big hole (with a plate over it) in the middle of the firewall, if it has the big hole it is before late 76.
PostPosted: Wed Jul 02, 2008 8:01 pm
The plate is in a shed 409 kilometers away
I need to know what the following numbers nean/are
M2
22
003
PA
PostPosted: Wed Jul 02, 2008 8:04 pm
Unfortunately those numbers by themselves don't mean a lot other than it's a square nosed mini of some form but not a GT as they were stamped M23 . How many coats of paint are there on the radiator shroud , is it possible the chassis number is hidden under the paint there ?
Those numbers alone aren't enough to identify or register the mini , you'll need to find the chassis/body number .
PostPosted: Wed Jul 02, 2008 8:15 pm
The Brithish mini site has helped.
the munber is the body number
PostPosted: Wed Jul 02, 2008 8:17 pm
According to the mini work shop manual some australian made mini's from 1969 made by layland did not have any numbers on the radiator houseing
Users browsing this forum: Bing [Bot] and 105 guests
