It is currently Tue Aug 12, 2025 11:48 am
 Post subject: Can't blow my horn
PostPosted: Thu Jul 03, 2008 8:58 am
I have 4 horns out of Minis/BMC cars. When I put a battery across the terminals I get nothing - except one makes a pop sound as though it's trying. Am I right in assuming they should work connected straight on a battery?
David L
PostPosted: Thu Jul 03, 2008 9:00 am
Yes they should.
If they are original BMC horns I think (??) they usually have an adjuster screw of sorts - maybe adjust it and see if it makes a difference.
PostPosted: Thu Jul 03, 2008 9:06 am
I agree with Anto, David
Sometimes they just old and freeze. Try giving them a bit of a tap.
Then try reversing the polarity. It shouldn't make any difference but sometimes it does. I don't know why.
The horns in situ have positive power in all the time and blow when the negative goes to ground.
Mike
PostPosted: Thu Jul 03, 2008 9:46 am
I've found a couple of sharp hits with a rubber mallet on the horn body to loosen things up can revive an old horn . I think a bit of corrosion can stick things together inside and earth the system .
PostPosted: Thu Jul 03, 2008 1:20 pm
Theres a screw on the back near the big one, loosen it until you cant hear the horn then screw it a quarter of a turn.
PostPosted: Thu Jul 03, 2008 5:09 pm
Give it a tap.
Turn the big screw in and out a bit to free it up.
Fine tune with the little screw.
They work fantastic after a tune. :D
PostPosted: Thu Jul 03, 2008 6:14 pm
sorry wombat somebody has to say this VIAGRA
PostPosted: Thu Jul 03, 2008 6:27 pm
Definately don't need it but there are a few people here that need some Viagra Eye Drops - as they need to take a long hard look at themselves
David L
Users browsing this forum: Sharri29 and 225 guests
