It is currently Sat Jul 19, 2025 8:25 am
PostPosted: Sat Jan 29, 2005 7:45 am
fuzzy-hair-man. Only one question.... why ... do you want to sway your clubman over for a roundnose?
PostPosted: Sat Jan 29, 2005 12:38 pm
poeee wrote:
Spaceboy wrote:
rear cards are 2 piece on morris and 1 piece on leyland.
No reason why they wouldn't fit though???????????
its the different placement of the ashtray that makes it fit poorly
PostPosted: Sat Jan 29, 2005 12:40 pm
i was giving this some thought and considering how hard it is to get a decent roundnose shell that requires little work it would be easier to just swap the front panels from a roundie onto your clubman
PostPosted: Sat Jan 29, 2005 3:58 pm
resident alien
resident alien
That's IT... you're grounded!!!!!!!!
PostPosted: Sat Jan 29, 2005 5:21 pm
fuzzy-hair-man wrote:
Any ideas on what a good straight shell with a little bit of rust is worth ? (I know how long is a piece of string) :wink: A rough figure would be good though
Apparently some clevage and great eyelashes will get you a shell + parts for free... :wink:
Seriously though I'm in the same boat finding out what bits and pieces can be swapped between my mini's..
PostPosted: Sat Jan 29, 2005 11:25 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
fruity for jd i can be swayed to look at yer parts Image
also i could borrow some of the realy good stuff to road test for you
makka
PostPosted: Sun Jan 30, 2005 8:40 am
makka
Image Image
PostPosted: Sun Jan 30, 2005 10:22 am
I've got a good clubman already :D and sorta wanted a roundnose, if I get a shell I can drive the donor clubman until I get the shell ready and painted then start swapping things over... this way I get to take it back to bare metal and then I know there isn't any rust eating my mini :wink:
Yer fruity I would but... I have no cleavage and I have a hairy chest :oops: :oops: :oops: :roll:
I didn't like the idea of chopping the front especially as I suspect the clubman has had a new front at some stage. :shock:
Roads need more corners
PostPosted: Sun Jan 30, 2005 1:45 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i have cleavege .......
and a hairy chest :(
makka
