It is currently Tue Jul 22, 2025 2:13 pm
PostPosted: Tue Jul 15, 2008 2:48 pm
I've done a search but can't find much detail. I was wondering whether there is a How To on removing an engine. (Whole engine & gearbox in one lot). Preferred removal via bonnet and not having to remove subframe. Maybe we can make one and put it in the how-to section?
-Alan
-Alan
PostPosted: Tue Jul 15, 2008 3:01 pm
remove carby
remove manifold/undo exhaust (if you've got a standard exhaust it's probably easier just to undo the flange)
undo earth strap
undo all mounting points. one near each wheel, one at the top near the radiator and one on the other side connected to the firewall
disconnect gearbox linkages
i think that's it. anyone?
78 Leyland Mini - Prince
PostPosted: Tue Jul 15, 2008 3:10 pm
Give Ash some flowers Nick .
DON'T FORGET THE SPEEDO CABLE! :wink:
PostPosted: Tue Jul 15, 2008 3:12 pm
oh yeah.... that guy. and probably the choke as well if you dont remove the carby.
PostPosted: Tue Jul 15, 2008 3:16 pm
:idea: You dont have to worry about that 'till the gearbox is at the top of the guards/wings (whatever you want to call 'em) just a bit easier to get at there 8)
PostPosted: Tue Jul 15, 2008 3:18 pm
and dont forget all the wiring, starter solenoid, alternator, dizzy, coil, and if you have it the oil filter.
edit: dont forget about the driveshafts.
anyone got know if its possible to take the shaft out without undoing the hub etc. i got the passenger side out alright but the drivers side is harder to get out.
need to change the shafts because changing from uni to pot
i should have taken pictures and done a how to when i took out my motor this morning
PostPosted: Tue Jul 15, 2008 3:20 pm
OH! and remove the bonnet. that's the first ting you should do. makes the whole process easier.
what's your mini?
PostPosted: Tue Jul 15, 2008 3:22 pm
what's your mini?
'78 Clubman. Should be easier than a roundy.
-Alan
PostPosted: Tue Jul 15, 2008 3:35 pm
ah yep same as mine.
also i forgot about undoing the hubs
PostPosted: Tue Jul 15, 2008 3:37 pm
disconnect battery
remove bonnet (Clubbies have a built-in scalp opener)
disconnect & tape up wiring: starter solenoid, alternator, coil, temp & oil sensors
undo earth strap
unbolt clutch slave cylinder
undo throttle & choke cables, undo fuel line and remove carby
cut the tie wire / cable ties securing the pot joint boots
disconnect speedo cable from gearbox as it's being raised
That's about it. Pot joints should just lip apart, then you can hunt for the missing balls as they drop out!
Or just disconnect all your wiring, remove shift, undo your subframe bolts, lift up the front and roll it all out complete....if hydro do it the above way then you wont have to re pressurise
PostPosted: Tue Jul 15, 2008 3:44 pm
Umm , steering and brake lines as well with that version ....
I prefer to take the engine out the top as awdmoke described , easier and quicker than taking the subframe out , then taking the motor out of the subframe as well only to have to reconnect everything on the subframe back up again as well .
PostPosted: Tue Jul 15, 2008 3:53 pm
Ooops....yeah steering rack might help too :oops:
And to add I didnt read the last bit of the OP prefering not to remove the subby...so big stuff up to begin with....
ah well can be excused, was up late last night putting finishing coat on engine bay :P
PostPosted: Tue Jul 15, 2008 5:11 pm
Just edited my post above to include unbolting of the clutch slave cylinder :oops:
PostPosted: Tue Jul 15, 2008 5:34 pm
:lol: Now you see why I didn't write it out myself , there's all the little things you do automatically but miss when you write it all out .
Mearcat , best idea would be to have a read through a workshop manual and look around the engine bay to familiarise yourself with everything . It is pretty straight forward and easy to do by yourself . Just make sure you have the car safely supported when you're undoing things underneath and use a good engine crane or endless chain that can support the engines weight .
Users browsing this forum: Bing [Bot] and 72 guests
