i am starting to assemble my gearbox i seperated the syncros inner and outer pieces and had the 3 springs and ball bearings out.
I know the which way the outer bit of the syncro goes (e.g. the bit that goes into selector forks)
but the inner piece which holds the springs and ball bearings seems to have a smaller ridge on one side and a bigger ridge on the other.
I am not sure which way this goes mainly on the 3rd/4th gear (the one with teeth closer to speedo bit) the 1st/2nd syncro with the smooth outer ridge. that inner piece looks like it can only go one way (thats with the bigger ridge towards the flywheel) look at pic to make sense. Does anyone know which way it goes the mini manual is not very clear on this bit
also got the gearbox aquablasted came up a treat
