It is currently Sat Jul 19, 2025 10:46 am
PostPosted: Sun Jan 30, 2005 9:24 pm
Guys,
I have a 1275 engine and when idling(in neutral) the gearbox makes a 'click click click..' noise.
But once you press the clutch in the noise goes away.
Is this ment to happen? Could this cause any permanent damage to the gearbox?
Matt
PostPosted: Sun Jan 30, 2005 9:29 pm
Are you sure its the Gear box :?:
PostPosted: Sun Jan 30, 2005 9:30 pm
Clutch release bearing.
Or some-sink like that.
PostPosted: Sun Jan 30, 2005 9:32 pm
Positive ;)
PostPosted: Sun Jan 30, 2005 9:35 pm
CLUTCH RELEASE BEARING. :roll:
PostPosted: Sun Jan 30, 2005 9:48 pm
When a car is idling the following are still moving inside...
Drop gears
first motion shaft and outrigger
Layshaft(counter shaft)
corresponding gears 1,2 and 3
With your foot on the clutch all these stop spinning.
my guess without hearing it would be first motion shaft bearing...
what sort of noise exactly
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sun Jan 30, 2005 10:02 pm
its a tapping sound.....
it is a clicking noise which happens at regularintervals... ie one circular motion as it occurs at regular intervals.
PostPosted: Sun Jan 30, 2005 10:04 pm
How regualar..or how quick is the tapping sound :!:
PostPosted: Sun Jan 30, 2005 10:05 pm
say every quater of a second to half second
PostPosted: Sun Jan 30, 2005 10:13 pm
Still thinking first motion shaft bearing.
Maybe the cage has broken and the balls are floating in the remainder of the cage.
They bunch up and "drop" one at a time as the bearing moves.
Drain the oil and see if any bearing bits come out, stick a magnet in the plug hole
PostPosted: Mon Jan 31, 2005 6:03 am
Primary gear rattle, I bet. Only does it when hot?? :lol:
Typical `old Mini' problem... no real problem. :wink:
Users browsing this forum: Bing [Bot] and 95 guests
