It is currently Sat Jun 28, 2025 1:00 pm
Post new topic Reply to topic  [ 218 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 15  Next
PostPosted: Thu Jun 19, 2008 8:32 pm
I love every thing you have done and think its brilliant but I have noticed one thing. In the pic's below which look like a Fuel filter it looks like one of the fuel lines is crimped on the centre & left where it enters above the front of the sub frame
Just something I noticed and think you should look at
'77 clubby van wrote:
hoo!
PostPosted: Fri Jun 20, 2008 3:16 pm
Thanks Gaf, but I think (hope :? ) that is just a shadow / mark on the tank behind it.
I'm pretty sure the lines are ok, but I will check tonight incase I damaged it without realising. :roll:
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Sun Jun 22, 2008 1:51 am
Nope not kinked...it must have been a shadow or something.
Got a bit more done today:
Fabbed the intake pipe and mounted the airfilter. (I had to keep some of the old mini engine bay bling!) Also painted up some of the intercooler pipe.
The rad has also been finished off finally (Modified inlet/outlet pipes and fan mounting) but the radiator guy is getting it polished by a friend who owes him a favour!! :shock:
Can't wait to pick that up!! 8)
-James.
PostPosted: Sun Jun 22, 2008 7:50 am
Looking good there Jimmy!
PostPosted: Sun Jun 22, 2008 3:58 pm
Does look good, how long till it's all done?
PostPosted: Sun Jun 22, 2008 4:17 pm
Planning to have it driveable by the end of july :shock:
Really I only need to do drive shafts and exhaust for it to drive. Whenever I get my dump pipe I will start the engine and make sure it runs ok.
There is a lot of little fiddly bits that I have to finish before rego. Plus I want to do a bit of bodywork and interior work!
-James.
PostPosted: Wed Jun 25, 2008 9:41 pm
Pics of the finished radiator in situ:
Its a bit tight in there! :shock:
Apparently my dump pipe should arrive on friday, so might be good for a try at starting on the weekend! :D Can't wait!
-James.
PostPosted: Wed Jun 25, 2008 10:56 pm
good news james! you will have to record a little video :D
at least the air filter will get plenty of cold air up the front there
the radiator looks snug in there to, i like how you have it mounted, pretty neat 8)
Mearcat wrote:
PostPosted: Fri Jun 27, 2008 10:46 am
Just be careful with that air filter James. In that location, it would be easy to get a gobfull of water into the filter and before you know it, you're pulling out the engine to repace a conrod.
That is of course if you actually drive it during the 1 month a year it actually rains in Kal :wink:
-Alan
PostPosted: Fri Jun 27, 2008 4:07 pm
Alan, I thought of the air filter getting wet there, but I figure I'wont be driving it in the rain that much, but if & when I do I will just attach a piece of plastic to the inside of the grill to blank off the direct flow into the filter. I may still do this anyway, but I like the look of it the way it is! :wink:
-James.
PostPosted: Sat Jul 19, 2008 6:19 pm
Okay, I've been pretty busy with work for the last few weeks, but I have made a big step with the project.
I've had some frustration, some success, more frustration, a bit more success, some disappointment, more frustration, a fair bit of confusion, and finally, today, some success. :x :? :D
I've had the car ready to "start" for a few weeks now, but as mentioned, I've been busy. :cry: I've also had to wait for my dump pipe to be sent (which ended up not fitting) as well as my new Odyssey battery to be delivered from perth. (who would have thought that a 6 hr drive would take over a week :evil: )
....Anyway, I had tried to start the mini with the old battery (been dead for about 8 months) jumped off my other car, but it would only turn the motor over without the plugs in. :?
So I got my new battery yesterday night and put it in and after a bit of cranking (maybe 10 - 15 secs) she fired to life!! :shock: But it was running rough and wouldn't rev. :( So I cracked it and went to bed!
This morning I had a few ideas to play with and had a good idea that a sensor was f**ked. Also for some reason my engine warning light is not working - I'm still chasing this.
So I made sure the timing was about right. - A little bit smoother idle, but still wouldn't rev.
Then I started pulling sensor plugs off until I found it. - The Throttle Position Sensor.
As soon as I unplugged it the car ran better (obviously the mixture was way out) and revved better than my ears could handle in the garage with basically no exhaust (only the standard dump pipe top 90 deg bend!)
So I need a new TPS! .... But at least it works.
I have a short vid of it:
-James.
PostPosted: Sat Jul 19, 2008 7:22 pm
Hot damn Jim, well done mate!
I am really getting annoyed that everyone has their car running except for me!
Good work mate !
Tricky
PostPosted: Sun Jul 20, 2008 10:23 am
It's alive. Big milestone there, well done!
PostPosted: Sun Jul 20, 2008 4:00 pm
Well done Jimmy
she purrs like a kitten,more inspiration I love it.
cheers Hallsey
PostPosted: Sun Jul 20, 2008 5:46 pm
Ahem.... :roll:
Life's a garden.... Dig It!
Users browsing this forum: No registered users and 23 guests
