It is currently Sun Aug 17, 2025 12:39 pm
 Post subject: Do I replace it?
PostPosted: Wed Jul 23, 2008 2:05 pm
Is it required, adviseable, desireable or un-necessary to changed the flywheel keyway washer and bolt during a total rebuild?
I've read where the bolt can stretch and loose it's holding ability and beside mine has a few nicks out of it where its been encouraged with a cold chisel. - and besides they're not that dear.
David L
PostPosted: Wed Jul 23, 2008 2:14 pm
I always chnage the washer
PostPosted: Wed Jul 23, 2008 2:28 pm
David if you`re sus at all then chuck it & get a new one... The bolt isn`t something you want to stinnge on,,, as long as the key washer isn`t all mashed up & if it looks good then use it,,, but a new bolt is the go.
PostPosted: Wed Jul 23, 2008 3:18 pm
Dr Mini sez bin the lock washer & use loctite on the bolt, torquing to 150lbft
I've done that on my last few (4 I think) -
PostPosted: Wed Jul 23, 2008 4:03 pm
Don`t confuse what i said about the "KEY" washer,,, i`m talking about the "KEY washer ,,, not the POS tin lock washer
PostPosted: Wed Jul 23, 2008 6:54 pm
do what your comfortable with after you have read everyones post
PostPosted: Wed Jul 23, 2008 7:16 pm
150 lb/ft is a bit much Simon, I use 130.
BTW I've never stretched/broken a flywheel bolt or bought a new one. :wink:
Users browsing this forum: No registered users and 332 guests
