It is currently Wed Aug 20, 2025 12:19 pm
 Post subject: Redrilling wheels
PostPosted: Wed Jul 23, 2008 4:58 pm
Forum Graffiti
Does anyone know if it's possible to re drill steel wheels? I have a set of 13" steels that need to be 4" pcd ( 114.3mm at the moment ) and want to get them re drilled.
Or if someone has 13" steels to fit a Morris Minor... :lol:
PostPosted: Wed Jul 23, 2008 5:21 pm
yeah you can get them re drilled i did this to my set of mags but you must get the old holes welded up. i got a engineer to do mine and then got a professional welder to weld up the old holes.
Cheers Dan
PostPosted: Wed Jul 23, 2008 7:00 pm
Moke wheels.......
8)
Sir Alec! we are not worthy!
PostPosted: Wed Jul 23, 2008 7:12 pm
I put Austin A30s on a `77 Moke... they were 13x3... :shock: :lol:
No you can't redrill steels, they are press formed to suit their particular PCD when made.
You can get many alloy wheels redrilled though, they are usually solid centre.
PostPosted: Wed Jul 23, 2008 7:18 pm
Forum Graffiti
That's what I thought :? Bugger... do you know of any other 13" wheels that would fit the Minor pcd? Only reason I'm doing 13s is because I have tyres, whitewalls, trim rings and hubcaps for 13's... a bit expensive to change size :P
PostPosted: Wed Jul 23, 2008 7:21 pm
I have a set of 13" steel moke rims here, so they exist alright.
PostPosted: Wed Jul 23, 2008 7:23 pm
I would put a set of Superlight 13x6 or something on a Minor. :wink:
My mate (Minor 1000 addict) runs Morris Major wheels on his now, they are 14". Better choice of tyres he says.
PostPosted: Wed Jul 23, 2008 8:27 pm
13inch diam & 7inch wide steelo moke rims like these that i have sitting in my yard ready to sell to anyone who wants them??? yeah ???-->
PostPosted: Wed Jul 23, 2008 8:34 pm
Forum Graffiti
Geez I would've loved those! :twisted:
The offset's too huge though :(
Anyone else!? :lol:
I think I'll place a wanted ad. Mini's are the same pcd right? ( 4 inch )
PostPosted: Wed Jul 23, 2008 8:41 pm
Give Ash some flowers Nick .
Yep, mini's are a 4x4" PCD :wink:
PostPosted: Wed Jul 23, 2008 10:36 pm
depends which minor... MM's are different to Series 2 / 1000's
cortina wheels will go on an MM
PostPosted: Wed Jul 23, 2008 10:47 pm
Forum Graffiti
It's got teeth :lol: Not the slats in the grille.
PostPosted: Wed Jul 23, 2008 10:54 pm
then I think you need to look to cortinas (and escorts I guess)
MM -
1000 -
PostPosted: Thu Jul 24, 2008 1:00 am
How soon do you need them. I know of a low light morry with either 5" or 6" x 13" rims on it. It is in a country wrecking yard that I will be visiting soon . Can check them out and let you know. The one in my pic had 7" and 8" x 13" holden stud pattern with 289 ford
www.minisprintgt.com
PostPosted: Thu Jul 24, 2008 12:03 pm
Forum Graffiti
In the next week and a half. Are they steels? The Morrie's got 13" 'hot-wires' on it atm, I hate 'em!
Freight might be a biatch tho... :(
Users browsing this forum: BIGGLES and 186 guests
