It is currently Sun Jul 06, 2025 1:36 pm
 Post subject: Angle of the dangle
PostPosted: Fri Jul 25, 2008 9:59 am
Anyone know the angle of the slope of the rear window? Would it be close to 80°?
David L
PostPosted: Fri Jul 25, 2008 10:17 am
I make it a bit under 70° according to my protractor.
It measures 65° relative to the driprail, but that runs downhill slightly at back.
PostPosted: Fri Jul 25, 2008 10:58 am
Thanks Doc - that means I need a Station Wagon high mount brake light - fits 57-80° 8)
David L
PostPosted: Fri Jul 25, 2008 12:27 pm
Yep that is correct, wait I'll find my pic.... :wink:
here- Image
PostPosted: Sat Jul 26, 2008 10:09 am
Supercrap didn't have anything so I dropped into Rip-co and found this - think it looks nice and compact and it swivels within the housing to accomodate any angle - $30
David L
PostPosted: Sat Jul 26, 2008 11:12 am
Looks good- let us know how it copes with the glass curvature. :wink:
PostPosted: Sat Jul 26, 2008 12:49 pm
Bugger :? The centre is about 1/8" off the glass :evil: I've dismantled it and figure the worst case I'll just fashion some clips to hold the LED strip each end direct to the window frame but before that I'll hit the case with a heat gun and try a bit of moulding to curve :roll:
David L
PostPosted: Sat Jul 26, 2008 1:56 pm
I bought the same one and found the curve in the glass was a bother too. I then tried to build it up with double sided tape, but that didn't work. It fell off anyway. :roll:
So, now, all I've done is used velcro at each end only and that seems to be holding. I figure I can still take it off any time if I want to clean the glass. :wink:
PostPosted: Sat Jul 26, 2008 4:41 pm
The Hella one in my pic above fits pretty good, as it's short.
I might have to buy another, as mine copped a bit of primer overspray during painting... using thinners on it would probably bugger the clear plastic.
PostPosted: Sat Jul 26, 2008 5:32 pm
I have seen some in other minis but never in a shop and I don't have a pic, that have the LED's (similar to Wombats) but instead of sticking to the glass they have a leg at either end and stand/mount to the parcel shelf. From memory they have a carbon fiber look finish, them's is the ones I want :wink: .
Users browsing this forum: John Sneddon and 92 guests
