It is currently Sun Jul 27, 2025 4:11 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Aug 07, 2008 3:14 pm
ausmini mod
ausmini mod
Howdy,
Didnt do any damage to anything or anyone, so turned out to be a very funny mishap...
Pete
PostPosted: Thu Aug 07, 2008 3:20 pm
You are very lucky, not much damage! I had a wheel go at 110km/hr in a 4X4 - not fun!
that looks worse than when it happened to me, but i was going about 70kph... ground a bit off the brake drum. funnily enough, it was the same wheel (eg. front passenger) and the wide offset 'tessas...
78 Leyland Mini - Prince
PostPosted: Thu Aug 07, 2008 3:21 pm
oops.....
I've never had a wheel come off completely (touch wood), but I got down to 1 nut once or twice. I used to have a nasty habit of putting the wheels on, but forgetting to tighten the nuts. Using hubcaps has worked well for me, the caps don't go on unless the nuts are tight
my mates dad was driving his car to Sydney and one of the wheels came off, broke all the studs, and broke the base of the pin & nut off the balljoint - he hadn't realised about the balljoint, I got the subframe from the car recently and spotted the damage - I might post a pic later if I remember
PostPosted: Thu Aug 07, 2008 3:33 pm
:oops: that nearly happened to me a month ago i tightened the nuts up with the wheel off the ground fairly tight then forgot to give them a proper tighten once i got the front wheels back on the ground luckly only had loose nuts didnt drop any. good to see no damage or injury
learn something new everyday, like when a second pair of pants come in handy at the most odd times
Enjoy Chris ;)
PostPosted: Thu Aug 07, 2008 4:15 pm
Did that with a rear wheel on the Landcruiser - 150 Km north of Leigh Creek in the middle of no where. Broke all the studs. 24 hours later we were on our way. Thank goodness the mine had Landcruiser and plenty of spare parts - new studs, nuts, bearings and seals (axle had to come out to replace the studs)
David L
PostPosted: Thu Aug 07, 2008 4:16 pm
Where is Josh and Emm with their Spiro the Moke story..?? :lol:
I check my nuts often for that same reason.
PostPosted: Thu Aug 07, 2008 4:24 pm
coming home from work in my first mini along Beach road Sandringham ,heard strange noise ,pulled up as the second last nut fell off. already lost the first two no 4 was loose, no wheel brace no jack .
real fun tightened the two remaining nuts up with a pair of pliers got me home just since then always check .
at Templestowe hill climb before it closed many years ago as a scrutineer handed a mini driver 3 wheel nuts that i removed with my fingers he was not happy you could hear him telling of his pit crew how displeased he was for quite some distance :( when he returned said "now get them #%^%%$ off" :D
PostPosted: Thu Aug 07, 2008 4:50 pm
Yep , been there done that too ... This is the damage to the sports850 from dropping front left wheel on the way to work one morning , sheared the ball joint bolt and nut clean off and ground a flat into the brake drum . I may be a little paranoid but I'd suggest replacing the bottom ball joint to be on the safe side .
I always use hub caps - you can hear the nuts rattling around that way :D
PostPosted: Thu Aug 07, 2008 4:55 pm
So what happened? Did the nuts work their way loose? Did the stud get threaded or were the nuts threaded?
PostPosted: Thu Aug 07, 2008 6:09 pm
Yep found that one out the hard way. No taxi drivers nearby, ready to pounce, were there? :P
PostPosted: Thu Aug 07, 2008 6:44 pm
lucky, how far did the wheel end up away or did it just plonk off?
PostPosted: Thu Aug 07, 2008 7:20 pm
Yep I had that happen years back a week after getting my brake discs professionally replaced...
felt a wheel wobble and went to pull off the main road.....
the wheel fell off in the middle of a roundabout (medium sized Canberra one) ...
Everyone thought I was mad "changing a tyre" in the middle of the roundabout!
Brake places response "You upset someone recently ?" :roll:
Funnily never been back to them...
PostPosted: Thu Aug 07, 2008 7:34 pm
Never let a tyre shop use a rattle gun on your nuts... wheel, that is.. :lol:
If they don't break studs they will strip the nuts. :evil:
Clubbies are worse, most have BRASS nuts.. :shock:
I park outside, and take my own wheels off thanks. 8)
