It is currently Mon Aug 11, 2025 4:42 pm
 Post subject: Fuel line?
PostPosted: Wed Aug 13, 2008 7:09 pm
(1) What is the size (diameter) of the metal fuel line pipe that runs under the mini?
(2) Is Bigger than standard worth getting?, I will be bending and flaring the pipe myself.
(3) Is their a special type of pipe I should get?
And finally, (4) is it legal to run the fuel and break lines inside the cab of a road registered mini?.
PostPosted: Wed Aug 13, 2008 7:13 pm
1/4 inch steel tube
5/16 if you are going to be racing with a thirsty carb setup according to Vizard. Doesn't need to be flared, and it may be bent without a bender if careful, but one helps to get a nice professional finish.
Steel bundy tube from places like ABS wil get the job done.
Hmmmm....I don't think so, but not sure...
 Post subject: Re: Fuel line?
PostPosted: Wed Aug 13, 2008 7:14 pm
(1) 1/4" OD.
(2). If going for more than 110HP I would replace it with 5/16" OD. There are no flares on it I can think of... :?
(3) Steel fuel line, it's sold by the metre. I got mine from Robbo's Spares.
(4) I don't think, so but stand to be corrected. :lol:
<edit> it's not really Bundy (properly spelt, `Burndy' tube) which is wrapped in 2 layers and bronze welded together. It's just round, thin steel tube, plated.. :wink:
PostPosted: Wed Aug 13, 2008 7:29 pm
ausmini mod
ausmini mod
same here.
I got bundy from brake place (8mm)
Its not legal to run it inside the car.
Pete
PostPosted: Wed Aug 13, 2008 7:38 pm
Yeah I didn't think it was legal but worth a shot :? I think I will just go for some 1/4 stuff in the "Burndy" pipe.
Thanks.
 Post subject: Inside Cab.
PostPosted: Wed Aug 13, 2008 9:43 pm
The Early VW Golf used to have Fuel and Brake lines running under the carpet and sound proofing. They were still approved for Ausstralian market. I quite like the Idea and it is just as safe providing you do not have any joins inside the Cab. I used to have my speedway Mini like that.
"Let us remove your "SHORTS"
PostPosted: Wed Aug 13, 2008 10:35 pm
ausmini mod
ausmini mod
The ADR's and safety rules dont allow fuel lines running through the cabin - unless the car was manufactured that way (Eg/ the VW) or it is engineered to be safe - no, sometimes they dont make sense but thats what they say.
Just like braided lines or braided brake lines, etc full race spec better than normal hose and they wont let them through... because you cant see if they are split or not...
Racecars, speedway, etc can do what the race rules say, very different.
Pete
PostPosted: Wed Aug 13, 2008 11:24 pm
It is definately spelt "BUNDY" The process was developed by British Tube Mills during WW2 as a replacement to copper tube. It is a steel strip that is copper plated then coated in tin and rolled to form a tube and then passed thru a furnace to melt the tin and seal it.
It is made in 2 layer to 11 layer[diesel injector tube]
It requires a double "cox head" type of flare or it will split.
The world market was supplied by BTM sth aust for many years ,but it is now made in most countries now except for Aust.
www.minisprintgt.com
PostPosted: Thu Aug 14, 2008 6:44 am
OK sorry I spelt it wrong, :lol: my point was that fuel line isn't made that way, it's just plain old soft steel tubing.
PostPosted: Thu Aug 14, 2008 10:51 am
ausmini mod
ausmini mod
David, not at all questioning your knowledge however when I ran my bundy tube I didnt flare it, I am using as fuel line so prolly dont need anything flared as the fuel hose (rubber) goes over the top (slips on) and a clamp is screwed over it...
If using for brakes (as the tube is intended) I am sure you must flare it, etc...
Pete
PostPosted: Thu Aug 14, 2008 8:46 pm
Picked up 2 meters today for $14. Now to install it, and I was only going to flair the ends to give the rubber pipe something to grip on to but if it starts splitting I will just leave it straight.
PostPosted: Thu Aug 14, 2008 11:28 pm
If you are only flaring the tube to clamp a rubber hose onto then it will be o.k. to use a single flare.It only needs to be a small ridge.
The only time you need double flare is if a fitting is used to attach pipe.
When bending tube use a pipe bender as the tube has problem with cracking and kinking during forming.
I have had plenty of experince with this type of tube, my father was head design engineer for BTM/bundy for 40 years and designed the new grades of tube and manufacturing machines.
Now we get it from bundy tube china
PostPosted: Fri Aug 15, 2008 8:12 am
How does one create the flare often used on ends of plane tube to hole rubber tube on?
I mean the one where it bulges the tube outward slightly just up from the end a little?
PostPosted: Fri Aug 15, 2008 4:49 pm
Another Q how tightly can the 1/4" be bent?
PostPosted: Fri Aug 15, 2008 4:54 pm
My bender (from BOC Gas & Gear) will pull it round a 25mm radius. 8)
Users browsing this forum: Bing [Bot] and 200 guests
