It is currently Thu Jul 24, 2025 11:13 am
PostPosted: Tue Aug 19, 2008 12:42 pm
NAV wrote:
will the hotter/colder plugs change the a/f mixture needed? i had to change my plugs from bp6es cause i broke one and found champion wadc in my other motor and the plugs have gone black and the bp6es were a dark brown
I just changed over to BP6ES from Champion N11YC, and the perfomance increase is marked - no run on anymore either
I had originally switched to Champions from NGK's, because I went through 2 sets of NGK in a week due to a batch of bad fuel - but now, bin the Champions
AFAIK, the heat range of a plug is governed by the length of the electrode - or how much of it is not covered by the ceramic - the longer the electrode is, the more heat it retains. So a hotter plug should be less resistant to crappy fuel, (edit) but worse in terms of pre-ignition and run-on. Though there may be a lot more to it than this
PostPosted: Tue Aug 19, 2008 1:03 pm
BALLISTIC wrote:
Up untill recently i had been using BP6ES and BP5ES and had been getting 1 or 2 "dead" ones in the pack or run the car turn it off, let it sit for a while, start it again and it would have a miss fire :x (didnt matter if the engine was well used or freshly rebuilt), so have changed to BP6EY & BP5EY and am yet to have any of the same problems with these spark plugs. :D
What do the 'S' & 'Y' signify? - What is the difference between the two?
PostPosted: Tue Aug 19, 2008 1:31 pm
Ok....now a question from a novice...
Olli is a bog standard 1100 'S' Auto....running NGK BP6ES.
I read earlier that a switch to a hotter plug (NGK BP5ES) gave more power and torque....
While I am not power hungry, some more torque would be useful.
So, if I were to change the plugs to NGK BP5ES should I get a small but measurable increase (5-10%???)?
Thoughts please
1969 Morris 1100 S Automatic
ahhhh......the interior smell of an old British car....
PostPosted: Tue Aug 19, 2008 4:08 pm
ausmini mod
ausmini mod
My Turbo 1132 is running BP5ES but looks like they may be fouling a little (its running a bit richer due to turbo, etc)
Hmmm, I cant run BP4ES as they are too hot and even with the 5ES I am getting some burning/pitting on the electrode.
Might try some bosch or Champion plugs ay.
Peter.
PostPosted: Tue Aug 19, 2008 4:18 pm
I doubt you'd see any improvement where your compression is low (unknown?) and there would be a lot of other factors dragging performance down, like buildup in the head, general state of tune. You could only suck it and see
In my case, the motor is fresh and I already have a fuelling problem, so a better spark made a big difference - my bum dyno reckons changing the plugs probably got me 4 or 5 bhp (out of 60)
Just give it a go Kez ;)
PostPosted: Tue Aug 19, 2008 4:21 pm
Peter.
from the NGK website
4. Heat Range
With modified engines (those engines that have increased their compression) more heat is a by-product of the added power that normally comes with increased compression. In short, select one heat range colder for every 75-100 hp you add, or when you significantly raise compression. Also remember to retard the timing a little and to increase fuel enrichment and octane. These tips are critical when adding forced induction (turbos, superchargers or nitrous kits), and failure to address ALL of these areas will virtually guarantee engine damage.
An engine that has poor oil control can sometimes mask the symptom temporarily by running a slightly hotter spark plug. While this is a "Band-Aid" approach, it is one of the only examples of when and why one would select a hotter spark plug.
Heat range selection is vital to ensure optimum performance of spark plugs.
A spark plug's optimum operating temperature is between 450 degrees C and 870 degrees C. Spark plug tip temperatures outside this range can occur when an incorrect heat rating is selected. Viz:
When the heat rating is too high:
The spark plug temperature remains too low and causes deposits to build up on the firing end; the deposits offer an electrical leakage path that gives rise to loss of sparks.
When the heat rating is too low:
The spark plug temperature rises too high and induces abnormal combustion (pre-ignition): this leads to melting of the spark plug electrodes as well as piston seizure and erosion.
NGK Spark Plugs pioneered the use of a copper cored electrode in 1958, which enables a spark plug to heat up quickly and also dissipate heat quickly giving an ultra wide heat range. It is essential to use a spark plug that fits a specific engine and its conditions of use.
PostPosted: Tue Aug 19, 2008 7:27 pm
I know a bit about this `copper cored electrode' caper... :lol:
The electrode wire that was used by Champion in their plugs made here was made by Lincoln Elecric Aust, I knew all their sales reps.
It is just steel submerged arc welding wire, 2.6mm dia ( I think) with a copper coating a few microns thick.
So much for the `copper cored electrode'... :P
If you don't believe me, cut one in half with an angle grinder and look at it.
This is called `marketing'.. :roll:
Here endeth the lesson.
ps. I bet a stock Bosch or NGK plug looks the same when cut...
PostPosted: Tue Aug 19, 2008 7:35 pm
Ben_Aus_Mini wrote:
What spark plugs should i use if i have a Mk1 G13B gti engine, Mk1 Head?
are these ok?
Usually how much HP or torque sees increasing for a good set of spark plugs?
Ad Description:
Performance Spark Plugs - $27/set of 4
Unlike standard spark plugs these have 3 electrodes giving a much better spark and much more efficient combustion giving better power and economy
i just used standard plugs as recommended for my mk3 GTi when i had it..
but this isnt the place to ask, try redlinegti.com
PostPosted: Mon Sep 08, 2008 9:08 pm
This space for rent
Apologies for the thread resurrection, but I've discovered I have BP5EY plugs in the new van, and I'm wondering how they're different to the BP5ES in the K.. anyone? NGK's website seems resolutely determined to reveal the part number code.
[edit] I've just figured it out -- the 'Y' plug has a 'v' groove in the electrode. Mystery solvered 8)
PostPosted: Mon Sep 08, 2008 11:08 pm
8) I find them to be a better plug
