Howdy,
Ok, I have a new ERA Relay/Fusebox controlling the lights (thats how I bought the car)
Its got 6 pins on it.
On the bottom it has the following
Middle Pin = +ve (Permanent)
Left Pin = High Beam
Right Pin = Low beam
On the top (where the fuses are) it has the following
Middle Pin = Earth
Left Pin = High Beam (switched)
Right Pin = Low beam (switched)
Now, my problem is that sometimes my lights wont come on... parkers come on, instrument cluster lights come on just the lights wont!!!
Anyhow, got my hands on a H4 conversion set and 2 x 4-pin relays... I can wire up the relays, no prob...
Issue is that I can hear my relay come on and off with the switch, but sometimes the +ve wire (permanent) seems not to have any voltage... thats when the lights dont work.
So my question is, what the heck does the wiring diagram look like for the light circuit.
Am I right that there is a +ve permanent feed to the light relay?
If there is, then I might have an issue in that actual wire (or the other end of it that connects to the solenoid (I presume, have not traced yet)
Thanks,
Peter
