It is currently Thu Jul 24, 2025 12:41 am
 Post subject: Engines according to me
PostPosted: Thu Aug 21, 2008 6:57 pm
I'm trying to work a few things out. I've got a new 202 head and want to know if it will do anything.
I'm an electrician so I have a small clue about stuff mechanical but it's not my day job. Please correct me if this sounds like poo.
It's an A Series 998. Now.... it smokes on deceleration and under hard load. So I figure the vacuum in the cylinders is pulling oil up and through/around the worn out rings burning and causing the smoke. But the rings aren't worn enough to smoke at idle.
Compressions are fair at 100-115, that tests the valve seals, correct? So I figure changing the head is a silly idea unless I do the pistons and rings too.
If this sounds like total BS please tell me.
PostPosted: Thu Aug 21, 2008 7:08 pm
Sounds to me the oil control rings are out to lunch. Which means a full strip, so most sensible people would check other items like big-ends, valves, guides & seals etc. whilst its in pieces.
How many kays since last re-build?
