It is currently Thu Jul 24, 2025 1:26 pm
 Post subject: Dash dimmer dial
PostPosted: Fri Aug 22, 2008 3:01 pm
Can I simply remove this dial and connect the two wires together? will this work at full brightness, with out burning/shorting anything out?
PostPosted: Fri Aug 22, 2008 3:09 pm
Should just work at full brightness
David L
PostPosted: Fri Aug 22, 2008 6:14 pm
Well that's what I figured I just don't want to burn any wires out.
PostPosted: Fri Aug 22, 2008 7:51 pm
Yes, removal will change the brightness from dimmer to dim... :wink:
Users browsing this forum: Bing [Bot] and 84 guests
