It is currently Thu Aug 14, 2025 1:01 am
PostPosted: Fri Aug 22, 2008 6:54 pm
hi, my brake master has finally died and i'm wanting to buy a new one. i have a dual stage master. i'm having problems buying a new master but i'm woundering if this brake master will fit my mini.
http://www.minisport.com.au/prod604.htm
thanks heaps
PostPosted: Fri Aug 22, 2008 7:03 pm
It should fit but not sure if the pipe fittings are exactly the same size, might pay you to check with some of the other part suppliers like the miniking and others and see what they have available, always good to shop around
PostPosted: Sat Aug 23, 2008 10:13 am
depending on how dead yours is you can probably get it reconditioned...
new sleeve, new seals. just make sure they don't block the lower opening... had that happen to me. idiots :P
78 Leyland Mini - Prince
PostPosted: Sat Aug 23, 2008 10:15 am
Kit for Oz tandem brake MC is `PBR’ K7800X.
Available from brake shops... :wink:
PostPosted: Fri Aug 29, 2008 4:23 pm
hi. thanks i have bleed up the system all brakes feel perfect. pedal feels good. pad are adjusted right but my rear brakes keep locking up under really hard braking. wat can cause this to happen.
PostPosted: Fri Aug 29, 2008 4:27 pm
The bias valve on the firewall has probably seized in the open position, sending full pressure to the rear.
Mini King has recond exchange ones available, I don't think you can buy these new now.
Either that, or you have put front discs on, and kept the standard rear 3/4" cylinders. The cure then is fit Cooper S rears (5/8") instead.
PostPosted: Fri Aug 29, 2008 4:33 pm
thanks. i have drums on the front. will i be able to pull apart the bias to find a simple problem. it did work before.
PostPosted: Fri Aug 29, 2008 4:35 pm
Slight hijack : twin leading shoe drums on front and fitting a booster - should I put 5/8" wheel cylinders on the back?
David L
PostPosted: Fri Aug 29, 2008 4:36 pm
I would try it first as is, `under controlled conditions' as they say. :lol:
PostPosted: Fri Aug 29, 2008 4:39 pm
I don't think you can easily get seals for it, I always understood when they were fubar you tossed them.
I'd talk to John at Mini King before you maybe bugger it up... brakes are not something to be messed with lightly.
Users browsing this forum: No registered users and 330 guests
