It is currently Wed Jul 23, 2025 7:11 pm
PostPosted: Fri Aug 22, 2008 10:00 am
The Mini King
you are Correct Kev, Early 850 had the semi seal beam
PostPosted: Fri Aug 22, 2008 2:00 pm
just fitted them and the car looks totally different! They are much cooler!!
PostPosted: Fri Aug 22, 2008 3:41 pm
The Mini King
Just for interest sake, the first type of Headlamps had a reflector (usually silver plated ) then a glass lens, I think in the 50's the semi seal beam was introduced the reflector was sealed to the lens, some time after this the sealed beam was introduced this was a totally sealed unit, The idea of sealing the lamp was to reduce oxidization of the reflector, This is about headlamps in general
PostPosted: Fri Aug 22, 2008 7:17 pm
The Mini King
Bret Wrote
Hi guys, what sort of headlights should my Cooper S have? It has been convirted to H4 with a flat front. I have a set of really curved ones , I don;t care about the lighting ability, just need to get it ready for the mini muster!
John Smidt Wrote
If You are looking for originality the headlamps should be Lucas seal beams, ( with Lucas in the centre of lens ) Any headlamp that you can remove the globe from the rear is a semi seal beam
Dr Mini Wrote
Early 850 etc pre-dated sealed beams... I'm sure my 61 never had them.
PostPosted: Fri Aug 22, 2008 7:23 pm
Got them fitted today, Went home from work, for a little while ( joys of being a company director)
THey realy have changed the front look of the mini. I couldn't believe it!! so much classier I feel. :D
Bring on the Mini Muster!!
PostPosted: Fri Aug 22, 2008 7:30 pm
Online
Just don't drive far at night, they are like yellow candles compared to H4s. :lol:
PostPosted: Fri Aug 22, 2008 7:36 pm
yep just worked that out :x oh well fashion over comfort as they always say!!
Users browsing this forum: drmini in aust and 111 guests
