It is currently Mon Jun 23, 2025 1:48 pm
PostPosted: Sat Aug 23, 2008 12:35 am
Angusdog wrote:
FYI not legal in NZ, unsure about Australia, but I believe you cannot legally retrofit them to vehicles here because of their outstanding brightness. Those that have them fitted also have self levelling suspension to (amongst other things) stop their lights from blinding other drivers.
My lights adjust their height, looks funny when you gas it!
PostPosted: Sat Aug 23, 2008 8:50 am
This space for rent
IIRC the ADRs also specify that you must have headlight washers with HID Xenons as well.
PostPosted: Sat Aug 08, 2009 11:45 pm
I'm in the process of fitting a HID kit in the van.
Can anyone tell me if it's ok to have the HID connections behind the headlights in the headlight housing or will these you beaut lights create too much heat in behind?
With the extra high voltage running the things I'm abit wary of how hot they might get.
Cheers.
Image Image
PostPosted: Sun Aug 09, 2009 10:03 am
Because of the way they operate and seeing as the wattage is only 35W, they do not generate as much heat as a normal halogen globe. You should be fine mounting the ballast boxes wherever, just make sure they are not gonna fall onto the road or get stones flicked at them and you should be fine.
Oh yeah, make sure they are well insulated too.
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
