It is currently Sat Jul 26, 2025 11:58 pm
 Post subject: idle issues
PostPosted: Sun Aug 24, 2008 10:08 pm
Got my 1 3/4 su on and tuned by a pro and it runs great but the idle position seems to only hold for a day at most.
is a lock nut on the idle screw the way to go? or can i loctite the idle screw in place? i'd use a medium strength loctite.
anyone got any ideas?
btw it's a 1275 with a cam, 1 3/4 su extractors etc etc so it's never going to idle smooth. i'd just like to get it set so it doesnt change everyday and i can pull up at the lights without having to heel toe to stop it stalling.
PostPosted: Sun Aug 24, 2008 10:56 pm
go back to your pro and get them to fix it...
PostPosted: Sun Aug 24, 2008 11:08 pm
my 1310cc with works cam, twin 1 3/4 idels nicely all day long and it hasn;t been tuned in 7 years. so your pro should be able to sort it. Thats why I won;t let anyone touch my SUs since the car was rebuilt
PostPosted: Mon Aug 25, 2008 12:51 am
Has your idle screw got a little coil spring between the head and the carby body. If not fit one. This stops the screw from vibrating out and up setting the idle setting.
www.minisprintgt.com
