It is currently Wed Aug 20, 2025 4:10 pm
PostPosted: Mon Sep 01, 2008 10:10 am
Ah Pedantry at its best
Does anybody know wether the diagonal grill stiffener fitted in MK1 Coper S australian production to clear the oil cooler ,was riveted or spot welded into the front body panel?
I recall seeing both used but maybe the spot welds were on later production (MK2). Then again maybe I saw the panel beaters art at its best!!!!
Mk1 Cooper S
Mini K Rally car
PostPosted: Mon Sep 01, 2008 10:59 am
To my knowledge, they were spotted with two spots, top and bottom. There seems to be a slight variation as to where they were spotted at the top, either as far rearward as they can go or forward about 1/4".
Regards
Al
PostPosted: Mon Sep 01, 2008 12:35 pm
High heel ninja
Both my 67 Mk1 & 69 MK2 are both spot welded in.
Doogie
PostPosted: Mon Sep 01, 2008 1:05 pm
My 69 is spot welded, but strangely there is a little pop rivet on the lower weld...it's not the usual kind of pop rivet, it's very small.
I've seen it as well on a mini K I had around here at the same location, so it's not a one off..
picture on the way..
PostPosted: Mon Sep 01, 2008 1:45 pm
My 67 Deluxe had the cooper style angled brace and is spot welded in 2 spots both top and bottom, must have been one of those "grab whats available" when put together
PostPosted: Mon Sep 01, 2008 3:32 pm
Our 69 S has the same. :)
Julie.............
PostPosted: Mon Sep 01, 2008 3:33 pm
High heel ninja
You mean Wayne's 69 S is the same :wink:
Doogie
PostPosted: Mon Sep 01, 2008 4:00 pm
Doogie
No - I mean OUR 69 S. 8)
Julie.............
PostPosted: Mon Sep 01, 2008 4:01 pm
High heel ninja
Doogie
:lol:
Doogie
PostPosted: Mon Sep 01, 2008 4:34 pm
My 68 Cooper S has pop rivets top and bottom.
But I guess that may have happened after a race crash in the late 60s. It has had a hard life and copped a big hit in the right front at some stage. I doubt if any panel beaters had spot welders back then. (I doubt if many had Migs back then! :lol:)
PostPosted: Mon Sep 01, 2008 5:23 pm
The Mini King
Both pop riveted and welded are correct In My Opinion, Over the years I have noticed both, Around 1969 they were welded more often than pop riveted, This is from my experience only, I am not saying this is Gospel
PostPosted: Mon Sep 01, 2008 5:41 pm
Here's the pic I promised.
Spot welded and the lazy rivet in the bottom. Sorry for the quality the camera is on the blink so can't take a new photo of the blasted brace...
It's a bit vague but the factory rivet is just to be seen in the bottom weld in the center.
PostPosted: Mon Sep 01, 2008 9:15 pm
Thanks to all for the response .
Seems like there is no definitive answer. It all started when I looked at my BMC published parts bookHYL3698 Oil cooler page AC12 and it shows rivets Part No DXR408 QTY4 This is an early Cooper S parts page ( around 1966). So rivets were certainly there for some part of the production life
Mk1 Cooper S
Mini K Rally car
Users browsing this forum: Bing [Bot] and 204 guests
