It is currently Mon Jul 21, 2025 9:23 pm
PostPosted: Mon Sep 01, 2008 2:46 pm
High heel ninja
There has been much discussion about removing a mini engine & whats involved, heres a guide of how to do it
The victim, my Mk1 Cooper S
Try to have a tidy work area, spend 1/2 cleaning up & sweeping the floor
I like to have my tools clean & organised
Now onto the process, step 1 disconnect the battery
Open the bonnet & remove the 4 7/16 headed nuts on the bonnet hinges, tip put some sheet foam or a folded up rag under the corners of the bonnet to prevent scrathes
Remove the grill, on rounnoses theres 4 screws, on a clubman there 7 also remove the bonnet closing panel on a clubman
Safely jack up the car & put study axles stands under & lower onto stands
Drain engine oil, sump plug is located on the front left of the engine, a 15/16 socket or spanner is needed
This is not uncommon, the sump plugs are magnetised so stray bits of metal stick to it
Remove the front wheels
If fitted remove the brake booster & steel brake pipes that plumb it to the brake system
A magnet on a stick helps to avoid dropping nuts into engine bay
Tip, a wheel stud screwed into the master cylinder & 3 way junction stops brake fluid loss
Now for the carby, if fitted with a weber, remove it complete with the manifold, if a single or twin Su's a fitted, remove the necks off the carbs
Undo top engine steady bolts & swing steady out of the way, Note some minis have another steady on the right side, remove this one
Disconnet the battery cable & wires from the solenoid, if needed mark the wires to where they go, or take pics before disconnecting, disconnect temp gauge, alternator & coil wires
If fitted disconnect oil pressure gauge piping & move aside
If fitted remove oil cooler & piping
unbolt clutch slave master cylinder & move aside
Undo both heater hoses & move aside
Under the car now
On remote gear boxes undo the 4 9/16 headed bolts & slip of remote housing
For rod change selector, put the car into reverse & tap the roll pin out of the sleeve, then remove the 1/2 headed bolt from the upper arm & remove
There are many styles of extractors all have the own way of coming apart im sure you can work out how to get them apart, on a standard maniflod, remove the 2 bolts & the clamp & seperate the manifold & exhaust
Universals, there are 3 types of mini universals, hardy spicers, rubber style & pot joint
In this cars case it has hardy spicer uni's, undo the 4 1/2 headed nylon nuts & move uni aside
Rubber uni style, undo the 8 1/2 headed nuts, remove the U bolts & uni
Pot joint, you need to undo & break the taper on the bottom ball joint & remove ball joint from control arm & pop driveshaft out of the pot joint
Undo engine mounts
Underside of the car should be done now
Undo the earth strap
Attach your engine lifting bracket
Engine is ready to come out now, attach your lifter, block & tackle etc etc
Begin lifting the engine, on remote style gearbox you need to tilt the engine as it lifts to clear the firewall
Once up high enough, disconnect speedo cable
Engine should be clear of car now
This is roughly what you sholud be left with
Depending on how many times you've done this, it can take anywhere from 1/2 hour to 10 hours.
This is a rough guide, it's how i remove a mini engine, im aware other have their own ways of doing it but hopefully this helps you a little
A few of these does'nt hurt either
Good luck
Doogie
PostPosted: Mon Sep 01, 2008 3:29 pm
Give Ash some flowers Nick .
That's excellent Doogie. I will try to twist "ausmini"s arm to get him to put it into the how to forum if you don't mind. That's excellent. BTW, fantastic choice of beer :mrgreen:
PostPosted: Mon Sep 01, 2008 3:32 pm
High heel ninja
Twist away Nick, the St George is'nt a bad drop at all.
Doogie
PostPosted: Mon Sep 01, 2008 3:45 pm
Very nice Doogie . can you post a "test" message in the for sale section so i can move it to the how to section without anyone replying to it and I'll copy your post to it there .
PostPosted: Mon Sep 01, 2008 4:45 pm
Good guide Doogie.
Love the choice of beer.
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Sep 01, 2008 5:51 pm
Top stuff! :D
Dave K.
PostPosted: Mon Sep 01, 2008 5:56 pm
this how to will be very helpful... thanks doogie :D
PostPosted: Mon Sep 01, 2008 8:23 pm
top stuff doogie, better than any workshop manual
PostPosted: Tue Sep 02, 2008 4:27 pm
and.... it gives decent pictures of what you should be looking at/for.
Great stuff. Many thanks.
PostPosted: Wed Sep 03, 2008 11:20 am
excellent...
now do one for the full engine and subframe removal...
Users browsing this forum: minimanic, timmy201 and 80 guests
