It is currently Sat Jul 19, 2025 2:16 pm
 Post subject: Disaster Averted.
PostPosted: Thu Feb 03, 2005 8:48 pm
I had the mechanics at work replace the rubber uni's on my Mini today. (luckily the mech boss used to have a mini when he was younger and thus is more than eager to volunteer his troops) They said the pax side literally fell apart as soon as they loosened the 3 remaining U bolts. One rubber piece was completely missing and the wear on the knuckles is somewhat concerning. Found one piece of the U bolts just sitting on the subframe. :shock:
I'm just glad I had it done before going to Lithgow, would have been awful ugly otherwise....
Dan
http://img.photobucket.com/albums/v517/djhaddo1/DVC01086.jpg
http://img.photobucket.com/albums/v517/djhaddo1/DVC01087.jpg
Margaret - 88 Rover
PostPosted: Thu Feb 03, 2005 8:52 pm
Holy crap haddo.................. they are screwed :shock: frightening stuff
:shock:
I got nuthin......................
PostPosted: Thu Feb 03, 2005 8:56 pm
Last time I got her serviced Ivan said they were on they way out. I didn't realise they would cark it so quickly.
Margaret - 88 Rover
PostPosted: Thu Feb 03, 2005 9:00 pm
That is some serious wear issues........... :shock:
PostPosted: Thu Feb 03, 2005 9:01 pm
Oil leaks kill the rubber... :x
You can get Nylon capped ones with needle rollers in them, they last much longer.
p/no is QL5000 I think. Around $110/pr at Karcraft. :wink:
PostPosted: Thu Feb 03, 2005 9:39 pm
:shock: YIKES!!
I haven't seen parts worn that bad, since my days at Qantas when we serviced an ex Pan Am plane!!
PostPosted: Fri Feb 04, 2005 7:33 am
dudes what was making that ubolt wear out so quickly?
Inconspicuously Conspicuous
PostPosted: Fri Feb 04, 2005 8:07 am
The rubber collapsed and wore thru, then all there is are the U bolts and centre cross... :x
Another thing to watch is the worn rubbers can rub on the gearbox casing and wear thru it! :cry:
PostPosted: Fri Feb 04, 2005 8:18 am
is there anything we should watch out for if we had steel uni joints?
PostPosted: Fri Feb 04, 2005 2:02 pm
I have been told that if you do not keep a good check on them and let them go like the ones you had. They can wind up flying through the gear Box and making a mess.
My Father has them on his 1310 for 5 or so years now and Never had a prob.
I was told that bu my local Mini Man.??????
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Fri Feb 04, 2005 4:46 pm
Oil and Grease on Rubber just does not Mix....
:idea: Think of the direction these guys are spinning... :!: Get under your Mini this weekend and have a check what you have and what condition they are in :idea:
