It is currently Sun Aug 03, 2025 7:01 pm
PostPosted: Thu Sep 11, 2008 9:11 pm
As the title says, when I select 4th gear the reverse lights go on (reverse also triggers them :roll: ).
It's on a rod change box.
What's worn out or broken and how do I fix it :?:
Right now I have unplugged the wires going to the sensor and hooked them up to a switch in the cab.
PostPosted: Thu Sep 11, 2008 9:14 pm
my sisters clubman was doing that too. turns out it was just the reverse switch was tightened up just half a turn too tight.
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
