It is currently Thu Jul 17, 2025 10:43 am
PostPosted: Fri Sep 12, 2008 6:24 am
I'm going to get a vent pipe welded into the rocker cover to connect to an oil catch can on the firewall. I've got one of Ben's SC12 kits that I will be installing soon so I want to be sure that the vent pipe won't foul anything on the SC kit.
I'm planning for the vent pipe to be in the top back corner of the rocker cover ie opposite #4 spark plug and be pointing directly at the firewall. Will that clear everything?
PostPosted: Fri Sep 12, 2008 6:39 am
have it pointing the drivers side arch rather than the firewall.
nope it will hit the inlet manifold. mine goes straight up and bends towards the inner wing as thats where I mounted the catch tank.
Heres mine
PostPosted: Fri Sep 12, 2008 8:28 am
Thanks guys. gr4h4m thanks for the photo. That helps a lot. Where I was thinking of having the vent pipe is at the other end of the rocker cover to yours - about where your Pclip is, but facing the firewall. From your photo it looks like it would just clear the plenum/manifold
PostPosted: Sat Sep 13, 2008 6:35 am
it will need to be very low at that point to clear the bonnet on a round nose..
I would do it last thing
PostPosted: Sat Sep 13, 2008 11:31 am
Here's what I've done. I used to have a breather off of the tappet covers on the rear (it's a Cooper S block) but it was too tight back there. So I covered that up and put 1 in the rocker cover, found that wasn't enough and put a second. Next thing I will do is throw away the clutch cover breather, make a new one and go with that. The problem is that the stadard one has a wire mesh inside to collect flying oil. Problem is, it does that too well, and in winter it all blocks up.
Wow my engine bay is dodgy, it is a daily driver though. Last time it was cleaned was about a year and a half ago.
I did wipe the rocker cover for the photo though
PostPosted: Sun Sep 14, 2008 6:47 am
I still use the tappet chest breather, I turned it up-side down and put it on the clutch cover and run a rubber hose to the catch tank
PostPosted: Thu Sep 18, 2008 4:51 pm
Thanks guys. Slinkey, I'm going to copy your setup, I hope that's OK and you don't have a patent :)
PostPosted: Fri Sep 19, 2008 4:24 pm
Nah that's cool. I appreciate that. :)
I should note, as it may not be obvious that my connectors on the rocker cover are screwed in.
A quick tap and drill did the trick.
Also the hose is petrol resistant hose, interestingly also for food use and was cheaper than fuel line which would be an overkill.
PostPosted: Sat Sep 20, 2008 8:50 am
Slinky do you have to watch the breathers when you do an oil change so the oil doesn't fill the catch tank whilst its dropping into the sump?
PostPosted: Sat Sep 20, 2008 2:19 pm
I did an oil change fairly recently and don't remember having to.
But yeah I imagine if I poured too fast it would be a problem.
Next oil change I'll hook the two sides of the rocker cover together with the one pipe (the hose connections are a nice tight fit, but twist off with some force) and just fill like you normally would.
