It is currently Sat Aug 02, 2025 8:27 pm
 Post subject: what size?
PostPosted: Tue Sep 16, 2008 10:04 am
what size socket does the flywheel retaining nut take????
PostPosted: Tue Sep 16, 2008 11:01 am
1 5/16 by memory Carter....for the flywheel to crank bolt
PostPosted: Tue Sep 16, 2008 11:13 am
ok thanks a lot jasonf...........i got it off but now need a flywheel puller........so have to wait for one of them.
PostPosted: Tue Sep 16, 2008 11:31 am
In a pinch, last 2 I removed I was able to use an 8" length of 4"x2" timber and a BFH....though both engines were out of the vehicles
Place the piece of 4x2 through the starter motor hole, give it a couple of taps with the hammer (well, pretty good taps), spin the flywheel round a bit, and give a couple of more taps, keep doing this until, if your lucky, the flywheel slips off....
PostPosted: Tue Sep 16, 2008 2:25 pm
yes hammer worked thanks a gain jason....turns out my clutch hasnt even been working at all.......
PostPosted: Tue Sep 16, 2008 4:15 pm
Geez you wont know yourself with a working clutch then lol
How is old Cowra going these days....got some relo's around there, and grew up in Forbes....havnt been out either way for about 20 years so guessing it is still the same :lol:
PostPosted: Tue Sep 16, 2008 4:17 pm
its going ok i guess.....although its getting a bit smaller. but hopefully our council elections will change that, next time yopur in cowra you should pop around....i go to tafe in forbes 3 times a week.
Users browsing this forum: minihahanz1 and 81 guests
