It is currently Mon Jul 28, 2025 6:36 pm
 Post subject: still no clutch.....
PostPosted: Tue Sep 16, 2008 7:30 pm
ok. so i pulled my clutch cover off and flywheel and that but my thrust bearing is stilll good nothing wrong with it. so i still dont know why i dont have clutch or what was wrong with it also checked that the clutch is on the right way and it is GRRRRR :evil: i just dont know what else it could be please someone has to know...................................
PostPosted: Tue Sep 16, 2008 7:33 pm
do you have photos of the set up? could be something missing?
Enjoy Chris ;)
PostPosted: Tue Sep 16, 2008 7:34 pm
ok...ill take some later on in the week and post them up....... it looks all ok according to my mini manual pics its all there.........
PostPosted: Tue Sep 16, 2008 8:12 pm
is it stuck engaged or disengaged? if it wont disengaged id question everything from the diaphram to the master and slave could be alot of things. is it doing absolutly zero or working with several pumps? any info will help. might be simple or it could be a problem for the experts on here
Enjoy Chris ;)
PostPosted: Tue Sep 16, 2008 8:15 pm
yea it does absolutely nothing...everythin moves l;ike the pole into the slave cylinder in and out but still wont let me go into gear no matter how many times i pump it.....
PostPosted: Tue Sep 16, 2008 8:18 pm
just another thought try gently putting it into gear as u rock it back and forth it may be a gearbox or selector thing and not a clutch but sounds like ur fairly confident its clutch. might not be pushing enough.
Enjoy Chris ;)
PostPosted: Tue Sep 16, 2008 8:21 pm
yea naa mate the clutch isnt even engaging.....
PostPosted: Tue Sep 16, 2008 8:27 pm
hjave you lightened the flywheel?
PostPosted: Tue Sep 16, 2008 8:47 pm
Have you tried adjusting the clutch?
Have you removed your arm to check the condition of the ball or if it is infact not broken?
Can you feel the pressure of the diaphragm spring against your pedal?
It wont be anything too disastorous or hard to fix, if it is infact the clutch that is the problem.
Post some pictures up or explain in depth what you have done and what it is or isnt doing
Matt
PostPosted: Tue Sep 16, 2008 8:58 pm
I agree with the above post, it sounds like end of the clutch arm has bent (i.e. the ball has moved right were is is connected to the arm), they often fatigue.
The same thing happened to a 1275LS that I had! :evil:
PostPosted: Tue Sep 16, 2008 11:42 pm
bummm.....
my clutch has problems i try and use it and it grinds and you cant put the pedal all the way to the floor
this happening must be inside the clutch housing - the fact that it makes a grinding noise when you put your foot on the clutch must mean something grinding against something else
maybe the diaphragm spring is broken, or the pressure plate cracked?
PostPosted: Wed Sep 17, 2008 8:54 am
simon k wrote:
bummm.....
Either that, or he actually means it grinds when he tries to select a gear?
PostPosted: Wed Sep 17, 2008 8:55 am
How did the clutch stop working (I'm asssuming it was working before and isn't a car you're trying to get going ?) , did it slowly get worse or did it just stop one day ? How old are the master cylinder , slave cylinder and hose ?
 Post subject: Re: still no clutch.....
PostPosted: Thu Sep 18, 2008 10:56 am
did you get anywhere with this?
PostPosted: Thu Sep 18, 2008 7:33 pm
Mines doing the same sort of thing. Clutch MC is new and bled it. Can get into gear easily when car is off but when its running it cant get into gear. Also when i try start it in 1st the car doesnt start when the clutch is in. Its all adjusted and the clutch arm is movie so not sure whats wrong with it.
