It is currently Sat Aug 02, 2025 10:08 pm
 Post subject: Note to self
PostPosted: Sat Sep 20, 2008 11:37 pm
This space for rent
TIGHTEN UP YOUR FRIGGIN' WHEELNUTS YOU STUPID @#$@%^*!!!
Been working on the van to get it ready for a RWC, and had the front wheels off a few days ago to replace the shocks. Been driving it around a bit since, road testing engine tweaks.
Did the oil & filter tonight, along with the rocker clearances. Time for another test run, then. Out we go on my usual loop which normally takes in a stretch of the West Gate freeway, but tonight I figured I had learned enough and took a short cut back home.
Bloody glad I did -- slowly taking a 90* corner a K or two from home and the inside front wheel goes knockedy-knockedy and feeds back through the steering. Knew straight away what I'd (not) done, so pulled over and nearly all the wheel nuts on both front wheels had worked themselves nearly all the way off.
If I'd taken the freeway, I reckon I would have lost one (or both) front wheels at warp speed :shock: :shock:
I've used up my luck for this week I think.
PostPosted: Sat Sep 20, 2008 11:42 pm
Lucky boy.
That could have ended in tears.
Image Image
PostPosted: Sun Sep 21, 2008 1:14 am
The TIG
Also important to check your wheel nuts regularly for a while after replacing wheel studs. I put some longer wheel studs when I installed my white sport pack wheels and everything was torqued up with my torque wrench like I always do and I drove around for a couple days. Then one day I noticed a weird feeling and could only think of one thing that could cause it, I stopped the car and sure enough the wheel nuts had started to loosen off. So I tightened them up and drove home. I torqued them back up and carried the torque wrench around for while and checked them regularly.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Sun Sep 21, 2008 2:17 am
i lost rear left at mallala a few weeks ago. i felt it so toodled towards pits, unfortunately it fell of on pit straight!
funnily enough another ausmini user who has the exact same wheel and tyre combo had loose nuts after his test drive. :?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
 Post subject: Re: Note to self
PostPosted: Sun Sep 21, 2008 2:36 pm
:shock: :shock: Scary stuff sgc!!!
Haven't seen you round mate ...... I live in Altona. Care to point me in the direction of some pics of your car so I can keep an eye out??
BC.
PostPosted: Sun Sep 21, 2008 3:53 pm
This space for rent
BC.
Don't get into Altona in the Minis much, I usually shuttle between here and work in South Melbourne. Closest is the Kmart and Burson's in Altona North ;)
Here's the K:
This is the van (now minus stickers and racks):
PostPosted: Sun Sep 21, 2008 5:53 pm
Give Ash some flowers Nick .
You're a lucky boy Simon. I bet it will be something you regularly check now though! :shock: Glad nothing happened and you realised what it was before it was too late.
PostPosted: Sun Sep 21, 2008 6:02 pm
:oops: unleast it didnt come of at warped speed.on the bright side you probaly will never forget to check them a again.
TUCK3R
PostPosted: Sun Sep 21, 2008 7:14 pm
This space for rent
I normally leave the car in the air until I do the nuts up, then the last thing I do when I put it down is tighten them up. No eye deer what happened this time around, brain fade most likely.. even though I tell myself not to forget it :roll:
You're right though, I'll find myself nipping up the wheel nuts every time I get in it for a while :lol:
PostPosted: Sun Sep 21, 2008 7:52 pm
ausmini mod
ausmini mod
Ar - me thinks it may be this one... :lol:
http://www.ausmini.com/forums/viewtopic ... ight=wheel
Pete
PostPosted: Sun Sep 21, 2008 8:00 pm
lucky lucky. too nice a car to get damaged with the wheels falling off.
PostPosted: Mon Sep 22, 2008 12:23 am
Pete
haha not quite! fellow saer actually!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
