It is currently Fri Jul 18, 2025 2:31 pm
PostPosted: Mon Sep 22, 2008 10:32 am
Hi,
does anyone know if there is a listing of what rims will fit these calipers. I know that mine won't. :cry: I had a look on the minispares site but could find a listing of which ones will...
Thanks,
2008 Prado GXL
 Post subject: 4 pot calipers
PostPosted: Mon Sep 22, 2008 11:33 am
If these are the alloy ones, I use miniator 10x6" rims which work for me. I think 10x5.5" will fit but haven't checked. The calipers can also touch on the suspension arms depending on your setup too.
PostPosted: Mon Sep 22, 2008 12:09 pm
Hi Rob,
do you fit the 10x6" rims under your flares as I'm going to need to get a roadworthy on this one, so want to have my bases covered.
10x6 sounds pretty neat though.
Thanks.
2008 Prado GXL
PostPosted: Mon Sep 22, 2008 4:06 pm
This space for rent
You know this already but for the sake of completeness my 10x5" standard-offset Contessa's fit ;)
PostPosted: Mon Sep 22, 2008 7:39 pm
How goes the van project Simon? I'd love to come around and see it.
2008 Prado GXL
PostPosted: Mon Sep 22, 2008 7:46 pm
Is it a big NO to standard steel rims over the 4pots??
PostPosted: Mon Sep 22, 2008 8:45 pm
This space for rent
Affirmative, no 10" steelies admitted to the party under any circumstances. 12's may, but I haven't tried any...
Slowly slowly, just getting it running properly and fit for RWC at the moment. You're welcome to drop by any time, bring the family for dinner ;)
 Post subject: 12 inch rims.
PostPosted: Tue Sep 23, 2008 4:45 pm
Rover Cooper
I got a set of 12's sitting in the shed, if you want to try them and have a look, just PM me and I will dropp them around.
PostPosted: Tue Sep 23, 2008 5:14 pm
This space for rent
Happy to submit as a test-dummy for fitting wheels over the MS 4-pot alloy calipers ;)
 Post subject: 12inches of fun
PostPosted: Tue Sep 23, 2008 11:19 pm
Rover Cooper
Just let me now when you want them, and I will bring them over or you can pop down to work in willy and pick them up, its up to you.
 Post subject: 10x6 and alloy calipers
PostPosted: Wed Sep 24, 2008 3:28 pm
My 12x5 minilite rims fit easily (and don't require arch-cutting to fit) so these are a good solution for road circumstances. 10x6 will definitely need flares, I have small 1.5" flares at the moment and 3" flares at the ready. They don't appear to be too far out but that's only because of the camber i'm running =)
