It is currently Sat Aug 16, 2025 1:32 am
PostPosted: Tue Sep 23, 2008 9:29 am
i am trying to sort out my breaks and need to know if the fittings are the same before i get braded lines made.
thanks gary.
PostPosted: Tue Sep 23, 2008 9:32 am
Front flexible lines are the same for discs and drums.
PostPosted: Tue Sep 23, 2008 10:04 am
Fittings are the same, genuine brake hoses for discs are shorter than for drums though.
PostPosted: Tue Sep 23, 2008 10:32 am
just consulted my newly aquired mini king catalogue and they are the same
PostPosted: Tue Sep 23, 2008 12:15 pm
I thought they were shorter, I remeber when I first put discs on my car I used drum brake hoses, and then they rubbed on the caster rods. So I got shorter "disc" hoses
But last time I bought them everyone was selling one length (that rub on the caster rods...) maybe the shorter ones are NLA?
Andrew
PostPosted: Tue Sep 23, 2008 12:28 pm
I'm surprised the shorter ones aren't labelled "cooper S" ones and cost twice as much!
:D
PostPosted: Tue Sep 23, 2008 2:48 pm
:D
QUIET Harley, you'll start giving suppliers ideas :lol:
PostPosted: Tue Sep 23, 2008 2:50 pm
Then someone will get this real bright idea that to avaoid the Cooper Tax on the short ones just use the long ones.
David L
PostPosted: Tue Sep 23, 2008 7:15 pm
Yes the disc ones are shorter but I've not seen them about for years.
Drum ones are OK, but swing the wheels from lock to lock and make sure they don't rub on the tiebars. If they do, rotate the top of the hose in the subby a little and retighten the nut. :wink:
PostPosted: Wed Sep 24, 2008 4:24 pm
The Mini King
after checking my records There has been aprox 6 superssions to the front brake hose I am not sure of the date that the short hose superceeded to the drum brake type but it was a long time ago
PostPosted: Thu Sep 25, 2008 10:12 pm
thankyou all
PostPosted: Thu Sep 25, 2008 10:25 pm
Drum and disc hoses are still available according to the UK sites...
http://www.minispares.com/Product.aspx?pid=34706
http://www.minispares.com/Product.aspx?pid=35885
