It is currently Fri Aug 15, 2025 1:15 pm
PostPosted: Wed Sep 24, 2008 4:16 pm
I orderd some new sunvisors from the UK and again I should never use a credit card when I've had to many beers :roll: This is what I ended up with.
http://www.newtoncomm.co.uk/cars/mini/p ... 249&type=7
They mount on one end with a locator near the mirror. I have fitted them in the car and would like to use them but I need to find some clips has any one seen this type sunvisor or know where i can get clips?
PostPosted: Wed Sep 24, 2008 4:48 pm
I believe the clips are available, but can't remember where from....
edit: it's label 63, part number ADA4370 in here... http://www.somerfordmini.co.uk/pdfs/Catalogues/Int-Body-Fittings/05-Headlinings-Sun-Visors.pdf
however, you don't want those sunvisors, you need to drill holes in the roof rail to fit them, and they'll be generally yukky..... I however could use a pair of them for my traveller, and I happen to have a lovely pair of original ones that'll suit your car
how about a trade?? ;)
PostPosted: Wed Sep 24, 2008 4:52 pm
sounds good deal to me Tony!
Simon if he declines, I'll get him drunk on Satuday arvo, so ask again later in the day! :lol:
PostPosted: Wed Sep 24, 2008 5:58 pm
The Mini King
This Type of sunvisor was fitted to the Aust Mini for a very short period the clip for the end was also used on the Austin 1800, for memory It does not look like the drawing in the somerford List however, The drawing in that list looks very similar to a bonnet Clip as fitted to the Mini Clubman, I would try a few general wreckers see if any of them have some austin 1800'S
PostPosted: Thu Sep 25, 2008 6:23 am
The clips are available from Newtons, very slightly different to the originals but will fit in the same way. They fit into a square that is punched into the inner roof rail, either side of the mirror. Some suppliers call them bonnet say rod clips. They were used on British Mini's in '65 only, but I have seen them on other BMC cars from '65, like 1100's. It might pay to get new ones as the originals are quite brittle now. To remove an original, you need to drive the centre pin right through, releasing the four lugs on the clip. You then have to recover the pin from inside the rail.
Regards
Al
PostPosted: Thu Sep 25, 2008 1:30 pm
ahh, see.... putting square holes in the roof rail isn't easy....
thanks for the detail Al ;)
PostPosted: Thu Sep 25, 2008 7:26 pm
My wife lived in wodonga an told me about people like you :D
I would be happy to swap my sunvisors for your traveller :lol:
PostPosted: Thu Sep 25, 2008 7:29 pm
nahh.... cos then I'd have sunvisors but no traveller to put them on, and I certainly won't go punching square holes in the roof rail of my cooper, that'd be just plain silly, now wouldn't it :roll:
PostPosted: Thu Sep 25, 2008 7:34 pm
The sunvisors are going in my deluxe and its got more mods than Michael Jackson face :lol:
PostPosted: Thu Sep 25, 2008 7:52 pm
My 1970 `Matic is getting Clubby visors this rebuild. Why?
They are black, and don't look like crap. :lol:
