It is currently Sun Aug 17, 2025 2:33 pm
 Post subject: Sandblasting $$?
PostPosted: Wed Sep 24, 2008 12:43 pm
Just thinking of getting some sand blasting done,
has anyone on here had a shell & doors blasted and what did it cost you
Thanks
PostPosted: Wed Sep 24, 2008 2:17 pm
Last quote I got, couple of years back, for the whole shell with doors, bonnet, boot etc. was $500 for the blasting and an extra $300 for red oxide priming. I didn't end up getting it blasted but I wish I had! Would have saved me at least 6 months.
Be very careful who you get to do it and ask to see some finished shells because if they use the wrong blasting medium they can do some major damage to the skins. There is also Sodablasting which won't damage the metal at all but I don't know much about it apart from that.
Gig
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Wed Sep 24, 2008 2:18 pm
High heel ninja
Soda blasting in Sydney is $400 a hour, around 4 hours or so to do a shell & panels.
Sand blasting is too rough on panels, bead blasting is better, once it was cheap, now it's not.
Doogie
PostPosted: Wed Sep 24, 2008 3:17 pm
Another option is to use paint stripper on the major panels and then have the edges and rust areas sand or bead blasted. This avoids damaging the flat panels and works out a bit cheaper. This has an added advantage of cleaning out your sinises and gives you a high on the fumes. :twisted:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Sep 24, 2008 4:11 pm
use a wire brush in an angle grinder works wonders
PostPosted: Wed Sep 24, 2008 5:09 pm
Glass bead (with a 10 percent garnet mix) inside and out, top to bottom, doors, boot, bonnet and one subframe, all finished in wattyl super etch primer....$750.00
Could have been done for same price in plastic bead at another place. These guys were closer and not so busy.
Nice job, no etching, no warping.
do it do it do it. Ask around however, some blasters are very rough. Paint suppliers are good peple to ask as well as panel beaters, as they have to deal with the aftermath of bad blasters.
When time is at a premium with work and family, the cost is well worth it.
PostPosted: Wed Sep 24, 2008 5:29 pm
wow that's cheap..I've looked at using these guys in sydney but they are quite expensive $1000-1500 :(
http://www.stripco.com.au/
Anyone got a good suggestion in Sydney?
PostPosted: Wed Sep 24, 2008 5:46 pm
Ring around, and keep asking for references. These guys open shop, close shop, change names, change owners more often than I've had hot dinners. :roll: They really are on the move.
PostPosted: Wed Sep 24, 2008 6:11 pm
mnnmnm would you say that it is a process for all restos or just for the very rusty ones
my shell is in fairly good nick just needs a boot and two front floors replaced all else is great really
i have bought the panels allready and there ready to be welded in
PostPosted: Wed Sep 24, 2008 6:33 pm
I had my van bead blasted twice and the first time was $1500, they put some sort of sealer on it but it only lasts so long... When i did that i rang around a few places and they were all about the same price (was in sydney at the time)
And Josh the blaster i used is just around the corner from enforcer at riverside rd
Life's a garden.... Dig It!
PostPosted: Wed Sep 24, 2008 6:38 pm
twice shiiiiiiieeeeeaaaaat :shock: at 1500 you must really hate rust
PostPosted: Wed Sep 24, 2008 7:22 pm
Yeah was a pain in the ass... Its what happens when beaters take their sweet ass time, it wasnt as expensive the second time round
PostPosted: Wed Sep 24, 2008 9:18 pm
Well for those in the Melbourne area, I would give thomastown sandblasting a call...these were the guys that did mine anyway....there's another in the area, forget the name, but they are a campbellfield. Same price, plastic media.
PostPosted: Wed Sep 24, 2008 9:27 pm
i sandblast every day :D
PostPosted: Wed Sep 24, 2008 9:28 pm
I find it therapeutic. I dunno how I would feel after the 8th hour however...
Users browsing this forum: Bing [Bot] and 372 guests
