It is currently Fri Aug 15, 2025 11:42 pm
PostPosted: Thu Sep 25, 2008 7:40 pm
Milatsmadmini
got a lowering bracket last week.... went to put it in yesterday.... but the bolt to un-do to put the bracket thing on (good english!) the nut part was rounded :(
how do i undo it? :oops:
PostPosted: Thu Sep 25, 2008 7:43 pm
This space for rent
If you can't get a pair of vice grips on it, take your dremel and cut it off ;)
PostPosted: Thu Sep 25, 2008 7:45 pm
Milatsmadmini
note to self: Buy dremel. lol
PostPosted: Thu Sep 25, 2008 7:47 pm
This space for rent
Yeah, I need me one of them too..
PostPosted: Thu Sep 25, 2008 7:53 pm
Angle grind a flat or 2 on it then use vice grips. :wink:
Or just cut it and the bolt off, then fit another.
PostPosted: Thu Sep 25, 2008 7:54 pm
This space for rent
Oooh, the combination approach. I like it 8)
Doesn't change the fact I still need a dremel :lol:
PostPosted: Thu Sep 25, 2008 7:56 pm
Dremels are toys, get thee a 1/4HP 24,000rpm die grinder.... :P
PostPosted: Thu Sep 25, 2008 8:02 pm
Milatsmadmini
cool.... well does anyone have a spare bolt then?
PostPosted: Thu Sep 25, 2008 8:04 pm
the bolt shop does....
PostPosted: Thu Sep 25, 2008 8:06 pm
Milatsmadmini
duelly noted.... take it then it is not a mini specific thing then.... will try cut off 2moro and get another nut :D
PostPosted: Thu Sep 25, 2008 8:08 pm
FFS don't put a metric bolt in it, it's supposed to be 5/16 UNF... :lol:
PostPosted: Thu Sep 25, 2008 8:09 pm
Weld a cheap socket onto it.
PostPosted: Thu Sep 25, 2008 8:26 pm
Milatsmadmini
cant weld :cry:
PostPosted: Thu Sep 25, 2008 8:29 pm
mattsmadmini wrote:
cant weld :cry:
Minis are like Valiants, their owners should learn to MIG weld, otherwise they are tied to the annual rust grind-bog-sand-spray routine every year. In NSW anyway.:lol:
PostPosted: Thu Sep 25, 2008 8:31 pm
Milatsmadmini
mattsmadmini wrote:
cant weld :cry:
i would if i had a MIG and someone to teach me... :cry:
Users browsing this forum: Majestic-12 [Bot] and 378 guests
