by far the easiest/safest way is to put the engine in the subframe, and lower the body down on to it.... I've done a few cars this way and it's painless - just get the angles right, and it drops down neatly
What do you use for a lift point on the body? How high do you have to go with it? Are wheels, universals, etc. already in place, or do you add those later? In other words, how do you account for the hydrolastic, brake lines, etc. going to the rear of the car--do you disconnect those, jack the body off the sub, add engine, lower body, reconnect rear stuff? Or is there a simpler way?
I'm in a similar situation (fixed overhead lifting point) but I just made sure there was room behind the car and pushed it back clear of the engine. Car moves easy without the weight of the engine - only takes one foot pushing
Seattle=Rain this time of year, so I'm trying to keep everything indoors. I found a 1 ton engine hoist on wheels for US$189 (gotta love Chinese child slave labor...) and will probably order that.
Well done - you are on the road to ruination as your confidence grows and you explore the innards of a mini motor!!
I fear you are correct. I'm already thinking about how I can sell one S, then find a cheap MK2 or similar for mods and fun, while keeping my MK1 S more pristine. My body and paint man: "You HAVE to have two minis. You just have to."
Here's a couple of pictures.
First one might show the lifting bracket--I wanted a bit thicker steel, but there is no indication of bowing/stretching/tearing/etc. Took all of 15 minutes to make it.
Second one shows that I'm running out of garage space and starting to get cluttered. I need to pause and organize/put away tools/throw out old stuff/consider my plan.
One thing I'm learning about minis already. On old air-cooled VWs, there isn't much you can't do with 8, 10 and 13mm spanners/sockets. On a mini, it seems that 3/8, 7/16, and 1/2 fit this niche also. And I'm (pleasantly) shocked at the engine mounts. Sir Alec was indeed a genius long long before his time. Imagine what he could have done with modern metals and manufacturing. John Britten comes to mind.
All best,
bmc
